Results 1 to 7 of 7
Thread: Added Stabilizer directly to pool
    Mar 2008
    Roseville,Ca
    30
    I am one for following all directions until tonight.Having no time to finish the job, I added 4lbs of needed stabilzer to my pool.
    DIRECTLY to the pool.I mixed it in a bucket but it still sat at the bottom like I expected.
    I brushed as much into intake as I could.
    Is it going to be okay?Has anyone else been the fool like me and done this and will admit it?
    Thank You
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    Casey's Avatar
    SW PA
    10,423
    Re: Added Stabilizer directly to pool
    *raising hand*
    ME! ME!
    I've done it and it'll be okay... it'll disolve in a few days.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    LOL, I'm sure I've done that or something like it....before my TFP days I dumped all sorts of chems in, "cause they told me too"....
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    It's NOT a problem for you to have added the CYA directly to the pool! However, if you don't brush it, it can take 7+ days to dissolve on the bottom .
    Congratulations on getting the pool ready to go
    Luv& Luk
    -Ted
    Guest
    Easiest way to add it is to slowly pour it into your skimmer with pump running, run the pump for 48 hours and don't clean your filter for a week. Test it after one week.
    Jun 2008
    Marana, AZ
    347
    That's the way I added my stabilizer - I got my pool set up before knowing what I was doing. It still did the job.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mar 2008
    Roseville,Ca
    30
    I have added stabilizer before but it was really fine and diluted and added to the skimmer.The stuff from Leslie's Pool Supply is terrible.I'll never buy it again.The other brand I bought dissolved so much easier.
