Results 1 to 12 of 12
Thread: Liquid Chlorine Brands
    I'll start with my CYA is 45....
    I'm using a gallon of HTH liquid Chlorine a day (light bather load 4ppl).
    Does this seem about normal consumption??? Trying to maintain 3-6 ppm
    20x40 IG Vinyl 35k gal, Hayward 24" Sand filter, Built fall of 2013, Single Speed Jandy 1.5hp Pump, Southwest Part of MI
    Using Tapatalk
    38,524
    Re: Liquid Chlorine Brands
    That gallon of 10% bleach is adding 2.9ppm of FC to your pool every day ... that is within the normal range which is 2-4ppm of FC daily.
    Is it still normal for the 3ppm of FC to be used up daily?
    Using Tapatalk
    38,524
    That is what I said. Normal is between 2 and 4ppm used each day. Raise the CYA some and you may lose less.
    Guess I should buy stock in HTH then, thanks!
    Using Tapatalk
    May 2014
    Lewisberry, PA
    93
    Liquid chlorine is Sodium Hypochlorite. Sodium Hypochlorite is Bleach! It is sold in various percentages and under various names.
    I see HTH liquid chlorine is 10% and about $12.00 a gallon? I'm sure you can buy liquid chlorine (Bleach/Sodium Hypochlorite) for much less. I buy Austin's Pool Tech Shock from Ollie's. It is 12% liquid chlorine (Bleach/Sodium Hypochlorite)for $2.39 a gallon. WalMart sells 8.25% bleach (Sodium Hypochlorite) for a good price also. There are many places and avenues you can buy liquid chlorine. (Bleach/Sodium Hypochlorite)
    Here is a copy of the link on bleach prices in our forum: http://www.troublefreepool.com/threa...ch-Prices-2014
    Good luck and stop paying so much!!
    Remember to buy only unscented regular bleach for your pool. You don't want your pool to smell like your washer!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    Not sure where you got your pricing for HTH, but we buy it at Wallmart for under 3$ a gallon Thanks
    Using Tapatalk
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by gardnerp81 View Post
    You should have a Menards somewhere nearby. They are selling 12.5% "liquid shock" (just sodium hypochlorite) for $1.98/gallon. Go load up your trunk, back seat and anything else you can carry it with!
    (And, yes, I'm using about 3 ppm/day.)
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    May 2014
    Lewisberry, PA
    93
    I just "Googled" it and that was the price on it somewhere....... glad you are not paying that much or just running to the "pool store" for it!!
    Good luck with the pool, enjoy the water!
    TF-100 Test Kit
    Just got back from Menards, got 24 gallons, thanks for the tip!
    Using Tapatalk
    38,524
    Please add your location (City, State or City, Country) to your profile and pool details to your signature and as described HERE as it will help us help you in the future.
    You will have to get off Tapatalk to get this set.
    Apr 2013
    Battle Creek, MI
    298
    You're very welcome! Glad to help out.
