Thread: Desperate timse call for desperate measures....
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Hi again friends
    You have probably seen my thread about my "dust" problem. Now that I have pulled the ladder out and got that all straightened out, I do have a question. I ordered a new ladder but it won't be here for a couple of more days. It was really time for a new one anyway. It is hot hot hot here today, so I really want to get in. I want to run something by you.
    I plugged all the holes that the ladder had on it (to let the water in to hold it down, I suppose?) with water proof duct tape (I read duct tape can fix anything...lol) and filled the ladder with a 50/50 ratio of bleach and water (seems to be holding ok), letting it soak to kill all the gunk that was inside. Should an hour be sufficient? I will then hose it all back out trying to remove the loose gunk. This is not an easy process because the ladder is way taller than me..lol...but would it hurt to cover the holes back up with duct tape before putting it back in the pool? I don't want to take any more chances of this happening again.
    And to everyone with a removable ladder, just to let you know, just because you see no algae on the ladder, doesn't mean it's not INSIDE the ladder....lesson learned. You can bet I will be pulling mine at least every other week to check the inside as well as the outside.
    Update: Just emptied the ladder from its soaking. The lovely shade of green that came out was amazing. Going to hose it all out and go from there.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Re: Desperate timse call for desperate measures....
    Using duct tape is a great idea. However, duct tape will not generally hold underwater in the long term.
