Results 1 to 13 of 13
Thread: ever treat the FC DAILY with bleach
    Mar 2009
    Charlotte, NC
    539
    Has anyone ever tried to treat the FC daily with bleach (not talking about the fancy gadgets that will do that for you)?
    For example, suppose you know that your pool requires a specific quantity of bleach every three days, the FC drops from 7 to 3 & you bump it back up to 7 every three days. If it is convenient because you are at the pool anyways every day, why not just put in one third of the usual amount daily and that will keep the FC at the higher 7 range rather than letting it get down to the lower 3 range?
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: ever treat the FC DAILY with bleach
    I think pretty much everyone here who is a jug-dumper adds every day.
    It's even listed as a daily task in Pool School: http://www.troublefreepool.com/conte...-care-schedule
    Daily
    • Look at the water, notice the clarity and color.
    • Test the chlorine level and adjust if needed.
    • Test the pH and adjust if needed.
    • Examine the skimmer(s) and clean if needed.
    • Use a leaf rake to remove any surface debris.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    I feed my pool every night. I do NOT have anything fancy to do it for me. I will say I test everything about three times a week unless there has been heavy rain or bather load.
    Kim
    DeeMac's Avatar
    May 2012
    Munster, IN
    123
    I add mine everyday. Usually in the early morning. I pretty much know now how much I need to add. So I test every few days to make sure all is in order.
    16 x 34 inground vinyl pool
    Hayward 1 hp super pump
    200s Hayward Sand filter
    Jul 2011
    Perrysburg, OH
    88
    Every evening about an hour before dark when the pool is finally in the shade... Good time for a cocktail too!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Sminor View Post
    Support the site
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Every evening about an hour before dark when the pool is finally in the shade... Good time for a couple Brews too!
    Same here, fixed it.
    My question would be, "why wouldn't it be done daily?"
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Another vote for "daily".
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Quote Originally Posted by kimkats View Post
    Kim
    This.
    after watching trends over several weeks, I know how hungry my pool is every day. I still test about 3-4 x weekly because the Speed Stir is just so darn fun!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by northrn View Post
    If you like the Speed Stir, you also need the Sample Sizer (Note, no relation to this vendor, just one I fund quick
    Support the site
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Every day and I have the white dots on my clothes to prove it. Just put a stenner pump in about a month ago. YIPPEEEE
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I test and dose every day. Usually about 20 - 35 oz. For my pool that's 2-3.5 ppm
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    jccams's Avatar
    Dexter, MI
    95
    Another daily doser here, usually after the sun is off the pool.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
