Results 1 to 10 of 10
Thread: Am I using too much bleach?
    RockingM's Avatar
    Jun 2014
    Dallas, TX
    13
    25,000 gal pool
    Free chlorine drops by approx 2 each day
    Combined chlorine is almost nonexistant
    Just switched pool from tabs to bleach last week
    ph at 7.8 consistently
    alkalinity at 130
    calcium at 210
    CA at 40
    I'm using 2-3 gals of bleach each evening. It pushes my chlorine up to 5 or 6. It stays steady overnight. But by day's end it's back down around 1-2.
    Does it seem right that I'm using 2-3 gallons of 6.00% bleach per day?
    25,000? gallon IG Plaster; Pentair FNS Plus DE Filter; 1.5hp Challenger PAC-FAB Self-Priming Pump; no heater; no cover; old Polaris with PB4 1.5hp Booster Pump. Built in 1970s. Replastered last year.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Am I using too much bleach?
    Editted
    2 gallons of 6% bleach is only 2.5 5 parts per million, which is reasonable. Taking CYA up to 50 might save a cup or two every day. high.
    Recheck that CYA and if it is indeed 40, something besides sunlight is eating it. An overnight loss test will confirm it. If it fails the test, you need the Shock Level And Maintain process. If the water's clear, it could still be done before the Fourth of July party.
    May 2014
    Ft. Wright, KY
    44
    Rocking M, I'm a newbie here, so wait for my suggestion to be seconded by one of the Pros. I'm responding because you've been waiting a while and I'm sure you'd like some kind of an answer.
    So, what is the percentage of the bleach you're using and where did you get it? Some of the dollar store bleaches aren't very high in actual chlorine, so you may not be getting much bang for your buck. Also, the bleach could be old, and it loses its potency over time.
    Are you using pool math? Two gallons of 8.25% bleach would raise my FC by 7 (I have a 24K gallon pool). I lose about 3ppm FC every day (so your 2ppm isn't bad).
    Also, how did you test your water for the 40 CYA?
    Somewhere to start! Good luck! Someone with more knowledge/experience will be along soon to help you further.
    Duh. If I would read your whole post and not be so eager to "help", I'd see you we're using 6% bleach. I'll go back to lurking now.
    24K gallon IG gunite (built 1976), plaster (Diamond Brite) redone (poorly) 2012
    Hayward EC65A DE filter Taylor K2006-C test kit
    Ft. Wright, KY (Cincinnati area)
    Don't argue. Just get the kit. TF100 or Taylor K2006C
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Do you test after you add to make sure you're reaching the point you think you are? Reason I ask is you may very well be using old bleach that's more like 3.5%
    When you say "FC drops by 2 every day" you mean 2ppm? if so 2ppm isn't much.(But your later statement contradicts that..) I found that 6% bleach is cheaper/gal but the irritation of using more than 8.25% was worth me using 8.25% (Until I can get my 12.5%). But if 2ppm is the case, then your bleach is absolutely not 6%....as per Pool Math It should take 104oz to raise your FC 2ppm. Similarly, 242oz (2x121oz jugs) would raise your FC by 4.7. I'm assuming that your "gallon jugs" are really 121oz. (which could be wrong, that's just the more common size where I live)
    What test kit are you using?
    No Chlorine loss overnight?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    RockingM's Avatar
    Jun 2014
    Dallas, TX
    13
    Looks like I need to do the OCLT test for a couple of days... Thanks for the feedback!
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    If your FC is 5 or 6 in the morning and 1-2 at night then you're dropping 3-5 ppm FC per day, right? Or am I confused? (it's been known to happen)
    Either your CYA level is less than 40 and a bright Texas sun happily eats your FC every day
    OR
    Something has set up shop and is happily eating your FC
    OR
    6% bleach is more like 3% in this case...
    How's the water? Sparkly and clear?
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    RockingM's Avatar
    Jun 2014
    Dallas, TX
    13
    Bumped up chlorine significantly last night (to 19 - I think my pool may be smaller than my measurements show). Performed the OCLT last night. Passed the test! Chlorine was at 18.5 this morning.
    VERY curious to see if chlorine "only" drops by 3 today...
    Smykowski's Avatar
    Sep 2011
    3,065
    Chlorine loss is a %, not an absolute value. Since you're starting the day significantly higher, your loss might be higher.
    RockingM's Avatar
    Jun 2014
    Dallas, TX
    13
    This test kit: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD
    Smykowski's Avatar
    Sep 2011
    3,065
    Raise your CYA to 50 and see if that helps.
