Results 1 to 20 of 20
Thread: Algae from!
    Jun 2014
    New Hampton ,ny
    7
    Algae from!
    I've done everything to try to get rid if this algae for the last week and a half. Ive had to change my sand due to it being clogged of debris and and it was also full of algae. Shocked after that and had no change.
    Reading after that z6/28/14.
    FC 9.53
    TC 9.53
    CC 0
    pH 8
    TA 37
    CA 87
    CH 247
    Had to drain about 15 inch. Of water and added new water.
    Reading today 6/30/14
    FC 1.44
    TC 1.74
    CC .3
    Ph 7.8
    TA 37
    CA 68
    Copper.2
    Iron .1
    cH263
    Now they are telling me to remove more water In Order to go forward and remove the algae. Please someone help me...I need to know can I go forward shocking or do I really have to drain again.
    AG 24x54 Mission vinyl 14,700 gal,
    Pentair Sand Dollar 40, (Sand Filter) gPM 40
    Dynamo pump 1.5 HP
    Installed2013
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    Also wanted to know can I use liquid shock with these numbers to try and kill the algae "
    Dynamo pump 1.5 HP
    Installed2013
    38,305
    Re: Algae from!
    Welcome to TFP!!!
    Well, the one thing you have not done is follow the ShockLevelAndMAINTAIN Process and to do that correctly, you need to invest in one of the Recommended Test Kits and stop trusting the historically horrendous pool store testing and advice.
    You should DEFINITELY switch to only using liquid chlorine because if the CYA value of 68ppm is to be believed, it is already/still above our recommended level of 30-50ppm, and the solid forms of chlorine may be raising this making your problems worse.
    There is not need to drain, there is just a need to learn and take control.
    Have you found Pool School yet? Start with these to begin your learning and ask questions as they come up:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    Can I use 4 gallons of liquid shock to start the process even though my cya is 67.
    Dynamo pump 1.5 HP
    Installed2013
    38,305
    Re: Algae from!
    You have to use PoolMath to calculate the amount of bleach you need to reach shock level.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Re: Algae from!
    CYA reading of 67 sounds like results from a pool store. Pool store readings are notorious for being inaccurate, especially CYA. Your first step should be to get one of the recommended test kits and do your own testing. Get the TF-100. You won't regret it.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    I'm in the process of getting the TF-100...well I Super shocked my pool with 4gal of liquid super shock and my water finally changed from a dark green to a bluish green...went to he pool store and they said not to shock again because my FC and CC was to high. The store recommended that I wait a day and bring down my ph with 2lbs add 2 gal of shock then backwash.....don't know if I should Listen to them....because they have been wrong so far...Here are my new readings.
    FC 20
    TC 20
    CC 0
    PH 7.7
    TA input 77
    TA op 54
    CH 244
    Copper .2
    CYA 69
    I scrubbed the walls and I'm waiting to later to backwash....should I super shock again. Please help! The store
    Dynamo pump 1.5 HP
    Installed2013
    May 2014
    Conyers,Georgia
    31
    Re: Algae from!
    As Jason said You need to use pool math to calculate.
    And Welcome to the forum
    35900 inground, 1 1/2 hp superpump, Jacuzzi sand filter, barracuda 3 cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Algae from!
    Quote Originally Posted by Shelly823 View Post
    No, you shouldn't listen to them.
    I know this is a lot of information to consume in a short period of time, but they are WRONG. Just assuming that your CYA is 67 (I believe you will find it much higher with your own test kit) you need to have a FC level of 28 to start really killing the algae (shock level).
    Are you getting the "liquid shock" at a decent price?
    What is the active % of the shock you are using (on the side of the bottle)?
    Until you get your test kit you will just be conducting a holding action.
    While your pH is nearing the upper end, I wouldn't add two pounds of acid.
    Things to do while you wait for your kit:
    Read Pool School
    Pick up a gallon of muratic acid from Lowes (blue label, 30% in the paint section usually)
    Read more Pool School
    Buy a bunch of chlorine; liquid shock if the price is right, plain old bleach from WalMart works too
    Pour a couple of gallons of bleach in the pool each day. It's not going to clear it up, maybe just hold off turning the pool into a full swamp.
    Fix a drink, it's really not that bad - you can do it!
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae from!
    2 pounds of what? Anyway, not needed. pH reads a false high when the FC is above 10, which the pool store apparently does not know.
    There is nothing wrong with the pH being 7.7.
    But, the best thing I can say is, don't trust those test results. When is your TF100 due to arrive?
    In the interim, you could add one gallon or two of bleach/liquid chlorine each evening, just to try to keep ahead of the green.
    You should backwash/rinse the filter when the pressure rises 25% above clean pressure psi.
    You're done SLAMing when:
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    Hi Tim
    I am using liquid chlorine...the price for 4 gal is 21.00 verses 3 Clorox for 9.00 at sams. Active ingredient is 12.5% which is more then Clorox which is 8%. Tonight I will be adding 2 more gal of liquid shock and pray it gets better...
    Dynamo pump 1.5 HP
    Installed2013
    38,305
    Re: Algae from!
    Why 2 gallons?
    Are you reading anything we are suggesting?
    There is no need for prayer, you need to follow the ShockLevelAndMAINTAIN Process using a Recommended Test Kit.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Re: Algae from!
    Both tim5055 ("a couple of gallons") and Butterfly ("one or two gallons") did suggest adding roughly that amount of bleach/liquid chlorine each day until the kit arrives.
    Presumably the prayer is for improvement before the kit arrives and the SLAM starts in earnest ?
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    38,305
    Re: Algae from!
    I missed that that the test kit was on order already ..... but no where have I seen that Shelly has started to use PoolMath to calculate dosages. Granted difficult to do when you have no test results.
    May 2014
    Franklin, NC
    9,184
    Re: Algae from!
    Jason,
    Yup, I just told her to add a couple a day to keep the wolf at bay until the kit arrives.
    Anyone got the formula handy for figuring the per oz cost? For some reason the 4 gallon 12.5% seems expensive for $21 to me.
    Support the site
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    Good news guys...my pool is finally back to normal. I woke up this morning found the pool with some green stains and it was a little hazy. I brushed the pool and backwashed and now we are clear. My question is now my FC is still 20. We are having a rainstorm right now so wondering will that bring down the FC? Do I still run the filter for 24hrs and if so how long do I do it for.
    Today's test from pool store. Test has not arrived.
    FC 20
    TC 20
    TA 48
    CYA 70
    Do I add baking soda to raise the alkalinity
    Thank u guys for all your help.
    Dynamo pump 1.5 HP
    Installed2013
    38,305
    Re: Algae from!
    Have you passed the OCLT? That is one of the criteria to stop?
    Is the water crystal clear? That is another requirement.
    Without your test kit, you can not know that you are done with the SLAM process.
    Jun 2014
    New Hampton ,ny
    7
    Re: Algae from!
    I don't have the kit yet but the water is clear.
    Dynamo pump 1.5 HP
    Installed2013
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Algae from!
    When will it be delivered?
  20. Back To Top    #20
    38,305
    Re: Algae from!
    ... but the water is clear.
    For now .....
    Why not follow the process and KNOW that there is nothing still in the water.
