Results 1 to 12 of 12
Thread: Upset with Intex
    May 2014
    San Jose, CA
    153
    Upset with Intex
    8 weeks ago , purchased a new SWG system from intex.
    4 weeks later the pump started to make grinding noises, i called Intex and they sent a replacement.
    Yesterday while the unit was running, after a min or two the service light went on and the pump shut itself off, i called Intex and they said that the unit might overheated and i should let it rest for a while and try again.
    That didn't help, so i called again today.
    Guess what? they want me to send the unit back on my own expense and they will fix it for me "under warranty".
    What am i supposed to do now? how can i manage at least 2 weeks with no pump and no SWG system?
    Please advice...
    Our Build 2016 14.5' x 26' IG Pebble, 14.5K Gal. 3.5' - 6.5' deep, 5 returns, 2 Skimmers, Hayward VS pump, Hayward 525 Cartridge Filter, Hayward E-Command 4, Heliocol Solar, Hayward LED Light, Paramount Ultraviolet, Polaris 280, AquaRite Pro, T-CELL-15, Sense and Dispense (HL-CHEM), Ph Dispense System (AQL-CHEM3) , Taylor K-2006 with SpeedStir
    38,298
    Re: Upset with Intex
    You can pour in bleach to get the required FC level and brush the pool to mix it in. Not ideal, but should prevent algae from starting.
    Casey's Avatar
    SW PA
    10,446
    Agreed. Not ideal but it will work. OR... you can ditch the Intex and buy something a little more reliable. Sorry you're dealing with this.
    May 2014
    San Jose, CA
    153
    Quote Originally Posted by Casey View Post
    Thank you, i've decided not to send the unit back instead through it out and buy a new system that can last. 300$ i'll never see again....
    I am thinking about the Hayward SP15922S (1HP 2 speed) and the AquaTrol, i'll leave the Intex 16" sand filter for now until it will die then i'll replace it.
    What do you think? can this work? i assume it is an overkill for my pool but i want something that will last.
    Casey's Avatar
    SW PA
    10,446
    Can't go wrong with a 2 speed. As soon as I can afford the switch, I'll be going with a 2 speed.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hey Casey,
    You've got options. You can use a toggle switch or even a standard 3 way switch. Depends on how you want to hook it up.
    May 2014
    Lake Forest, IL
    53
    Did you buy direct from Intex? Tell them you want your money back. If you make a big enough stink they may take it back. If you used a credit card you may be able to go through the credit card company.
    Intex Ultra Frame 16' by 48" deep - Pentair Superflo 1.5 HP pump with sand filter, Hayward H150 Heater, Hayward Skimmer and 2nd return
    Mid Missouri
    227
    I'm in my 3rd trouble free season with my separate Intex filter, and Intex SWG. At an approximate cost of just over 300 bucks for both.
    I'm not sure insinuating inherent brand reliability problems is appropriate. Every company puts out an occasional lemon, and of course there is always the possibility of operator error.
    I would push for a satisfactory resolution with Intex or your point of purchase depending on where that was. It sounded like possibly you purchased the unit seperatly? Do you have another pump as a temporary source of circulation?
    May 2014
    San Jose, CA
    153
    Quote Originally Posted by The Diesel View Post
    I bought it on May 9th 2014. from VMinnovation which is one of Intex retailer.
    I ask them to take it back they don't want to, who wants to take garbage back? i am very upset, i wish i new this in advanced, as of now i will never buy Intex again.
    May 2014
    Lake Forest, IL
    53
    Another thought is to go on craigslist and buy a used pump. That is what I did. Replaced my intex with a pentair superflo.
    Quote Originally Posted by Yaniv View Post
    Not even two months old, that is total BS. I try and buy everything I can, at Sam's club, costco, home depot, amazon. They have always took care of me even when the manufacturer was giving me the run around on warranty.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Have you spoken with Intex directly? I had an issue with my sand filter pump 4 years ago and they replaced it. No issues since.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    May 2014
    San Jose, CA
    153
    Quote Originally Posted by GreatCanadian View Post
    Yes I did, i have a problem with the replacement they sent.
    Just so you all know, they will only replace once during the warranty period, after that you will have to pack and pay for shipping to them, once they get it they will fix it for you and ship it back (2-4 weeks time)
    Every decent manufacturer would have send you a replacement and ask you to put the old one in the replacement's box and ship it back to them free of charge.
    I guess i am used to a different kind of costumer service.
