Results 1 to 7 of 7
Thread: Teflon base do-ring lube
    Jun 2014
    860
    Is Teflon based lube OK for o-rings?
    I want to lube up my pump pot gasket but I don't want to use the wrong lube. The brand I got from Ace is called Tube Lube and it says it can be used in marine applications.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Teflon base do-ring lube
    Normal pool lube is silicon based.
    Looking at the label, I'd say you could use that.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    What you have is what is sold at most pool supply stores.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    38,407
    I think the teflon based becomes tacky after it is applied, which is annoying and hard to clean off. Once the teflon stuff I have is gone, I am going to find some silicon based stuff.
    Jun 2014
    860
    Yeah. I remember from my lab days of working on vacuum equipment we stayed away from anything Teflon based for many reasons (volatile precursors, cross-linking reactions, hardening, etc).
    I think I'm gonna ditch the stuff and try to find a silicone based lube.
    Does anyone know a good silicone based product that the pro's use?
    38,407
    James had good suggestions here: http://www.troublefreepool.com/threa...al-lubrication
    Which is where I learned why the lube I have does what it does and why I am going to switch.
    Jun 2014
    860
    BOSS 820 lube description on Amazon:
    Product Description
    This pool and spa lubricant is a silicon dioxide thickened, high molecular weight dimethyl polysiloxane-based material. It is a stiff, tacky dielectric compound with excellent water repellency. Pool and spa lubricant was designed for use as a water repellent, sealing compound. Grease-like consistency, high tack, chemical inactivity and superior dielectric properties make it an excellent choice for use in water applications. It is an excellent release agent and lubricant for rubber and plastic parts such as O-rings, valves or plastic gears. Boss pool and spa lubricant is the premier product for lubrication in the pool and spa industry. Available in clear color and 3-ounce size. Includes 1 lubricants per pack.
    It's $11.95 for a 3oz tube. Pretty expensive but it sounds like the right stuff. I suspect 3oz will probably last years.
    Thanks all!!!
