Thread: Solar panels on grass?
    Jun 2014
    Toronto, ON, Canada
    98
    Hi all,
    I was thinking of buy a couple 2'x20' solar panels and just placing them on the ground beside the pool. Is it okay to do this? I have about 5' on one side between the fence and pool and would put it there. I was also thinking of building a small triangle box so I could put maybe 8'x20' worth of panel in the same area.
    Thanks.
    Jun 2013
    Manitoba, Canada
    153
    Re: Solar panels on grass?
    I laid mine down on top of some shipping pallets, but lots of folks lay on the grass. The drawback is the grass does grow up through the little slits like the coil I made does, that is why I used the pallets.
    Jun 2014
    Toronto, ON, Canada
    98
    Okay, so on the grass is not a problem for the panel. I was planning on placing some fabric under the panel to prevent stuff growing through it.
