Thread: Changing the bulb in an underwater light
    Jun 2014
    Danbury
    9
    So it looks like my pool light was left on all winter and the bulb is now burnt out. I've never changed the bulb before, so before I start unscrewing things I wanted to run a few things by you guys. This light is a circular light that's about 2 feet below the surface and is cut into the liner. There looks to be a wide trim ring around the outside with 6 or 8 screws and then there are two other screws, one on top and one on the bottom that have holes cut in the trim ring so you can access them, but they're underneath it...if that makes sense.
    Which screws do I want to take out to just remove the bulb? Is there any possibility of me causing a massive leak here?
    28,000 gallon
    inground
    vinyl
    DE filter
    Aug 2013
    Maryland
    93
    Re: Changing the bulb in an underwater light
    I'm not sure I could tell you which screws, but the general way lights are put in is that you unscrew them from their mounting niche and there will be enough wire to bring them up to the pool deck to work on them.
    Mine have 2 screws holding them in place, unscrew that and you can pull them up to the surface.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I'd remove the two with access, the entire light should come out as a sealed unit. THen you can work on the builb replacement in the dry (turn off the breaker before touching anything).
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
