Results 1 to 9 of 9
Thread: Pool being repaired, tile, plaster, leak ? balancing water when done?
    Jun 2014
    Scituate, MA
    25
    Hello,
    First, Thank you all for helping me with my pool questions. I appreciate it so much.
    I'm having my 33 year old Anthony Gunite pool repaired. Tile replaced, plaster areas done, small leak at skimmer. About two feet of the pool will be emptied. How difficult will it be to rebalance the water that I'll have to add? I've never emptied that much water out before.
    I'm excited about the repairs being done. It's in very good condition for such an old pool. Maybe I'll get another 33 years out of it.
    Thanks, Patty
    Gunite Pool Inground, Plaster, Built 1982
    20 x 40 paisley, 8 deep end, 3 shallow end, 26,000 gal - 30,000 gal ??
    Filter - Apolo Mode VA 38, 38ft, pressure 50lbs, flow rate 95 GPM, 22 lg., 40 deep, 20 wide
    Model No. C48K2PA105C5, 1 HP 115/230 3450 RPM 60 HZ
    Mar 2014
    Las Vegas
    288
    Re: Pool being repaired, tile, plaster, leak ? balancing water when done?
    Shouldn't be too hard. What test kit do you have?
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    Scituate, MA
    25
    Hi jmbradwell,
    I bought the FT-100. The pool will be done by Thursday morning when I can start adding water. I have about 6,000 gal. to put back in.
    Butterfly's Avatar
    South Carolina
    10,045
    You should be able to balance it in a snap!
    We'd like to see some pics
    You're done SLAMing when:
    Mar 2014
    Las Vegas
    288
    Once you get it topped off, Run a complete set of tests and post your numbers. It won't take much to get it in balance.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, at least circulate the water for a few hours before testing. You want to get a good mix for testing.
    Jun 2014
    Scituate, MA
    25
    I'm not sure if this works, but I have pictures of the pool at this site.
    http://s1265.photobucket.com/user/pc...8c030.jpg.html
    Jun 2014
    Scituate, MA
    25
    I posted some photos at
    I wasn't able to have the whole pool done, still a few places where the plaster has bubbled and fallen off, but only a couple. Hopefully I can get a few more years grace.
    Jun 2014
    Scituate, MA
    25
    Pool repairs done. Waiting for the Dalton Pool Water truck to deliver the water tomorrow. I was nervous to add town water because they are flushing the lines and our house water is coming up brown. Even if it wasn't brown I was afraid of the water balance of the town water. Not sure if town water would cost more and didn't want any hidden charges popping up either.
    Water doesn't look too bad. I've kept the chlorine level up and pH is good. Needs to be filtered to remove the cloudiness, but I'm hopeful it will be ok. We'll see what the water reads after the new water is added and I can get the filter running.
    Next, cleaning up the patio stains and replacing an old fence.
