Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Pool is up and 1st TF-100 is complete, now what? goal-swimming on 4th of July!
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Question Pool is up and 1st TF-100 is complete, now what? goal-swimming on 4th of July!
    I was hoping to get chemicals tonight but I had a drip I needed to get great white sealant for and finish topping my Intex 16x48 off! Finally got it topped off and 1st test results in! Just regular Intex 635T pump with hayward skimmer added.
    Figured I'd come to the masters for my 1st round to get it balanced. I know we have a calculator but id like to get the basic pro advice and I'll be at work tomorrow and hoping to get chemicals on way home and be swimming on the 4th of July. I know I can add bleach and shock or acid....learning the ropes so bare with me. Do tablets in floater work best once levels are reached?
    Figured I'd post my results, water from hose only and no chems-
    FC -2 (4 drops)
    CC- 0.5
    Total Chlorine- 2.5
    CH- It turned blue right after adding the R-0010 (maybe due to water softener?)
    TA- 90 (9 drops it took)
    CYA- 0 (filled the whole tube and can still see the black dot, no chem in pool!)
    I was cautious with my first test but wasnt too bad, when I opened the kit I was like o **** what did i get myself into lol!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Pool is up and 1st TF-100 is complete, now what? goal-swimming on 4th of July!
    CYA is definitely 0 in fill water because it doesn't occur naturally.
    We do not generally recommend the use of tablets because tablets add both CYA and chlorine - the chlorine is used up but the CYA remains.
    With a vinyl pool, you don't need to add CH.
    You need bleach and CYA.
    Jun 2014
    206
    So I'm picking up a Jug or 2 of 8.25% oz concentrated reg bleach.
    Tfp method shows 15 Oz of bleach to add.
    As far as CYA stabilizer is liquid or powder better? Looking a HTH stabilizer from wally, recommended in sock or knee high nylon tied to pool edge by return.
    Do I need to add the 12oz of baking soda to bring my TA up?
    Should I walk around pool as dumping from measuring cup?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Slammed01 View Post
    As far as CA stabilizer is liquid or powder better? Any good ones at Walmart?
    Granular CYA is cheaper than liquid. Walmart sells HTH stabilizer at a good price. You don't need to raise TA. How to add each chemical is spelled out in this Pool School article.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    What's your pH?
    The pH test is in the blue box in the kit. The color block thing. You don't need to do the chlorine test with it (yellow color match) since you have the FAS-DPD test but that's the only pH test in the kit and I didn't see you post results from that one.
    Welcome!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jun 2014
    206
    I just thought about that this am, will do tonight and post results. What do I use to increase PH from Walmart ? Might as well stock up!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    18,967
    How do you know it needs raising?
    The recommended pool chemicals and how to add them are in this article.
    Jun 2014
    206
    I'd rather have access to it than to have it and not need it....Im sure I'll need to raise at some point
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    18,967
    How can you be sure? I've never needed to raise my pH in over four years of being open year-round.
    Although I guess if the pool never needs it, you can use it in the laundry.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I've never had to do anything to my pH. It always just sits at 7.5-7.8.
    Hmmm, well I used a couple of pucks to get my CYA up and they lowered it to 7.2 but still in range so I'm leaving it. :P
    Jun 2014
    206
    Thank you for the knowledgeable link, I just read up. So nice not relying on Leslie's! Never been so excited to go to wally world after work haha!
    One last question, how do you all measure the amounts? Prob make a "pool measuring kit" with my chems. Bleach I can use a measuring cup, how bout liquid or powder stabilizer?
    Sorry I'm a rookie!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Sure, we recommend you use plastic measuring stuff. The PoolMath calculator will tell you how much to add by volume and by weight.
    A link to PoolMath is in the menu bar at the top of each page.
    Welcome to the forum
    You're done SLAMing when:
    Jun 2014
    206
    Yea I did the calculations so I have my bleach and stabilizer amounts noted for when I get home. I'll add measuring utensils to my list too!
    After adding tonight, do I want to run filter and recheck tonight or tomorrow?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Have the filter running when adding chemicals. You can retest FC 30 minutes after adding.
    Add the CYA via sock method and don't test for a week.
    After CYA is dissolved from sock, assume it is in the water and adjust FC levels accordingly.
    Jun 2014
    206
    So happy to read I can swim while the CYA dissolves, I will put that in my skimmer basketball give an occasional squeeze over the next few days!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Any recommendations on a good walmart measuring tool assortment? How do I measure stabilizer?
    Since bleach measuring cup for oz
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Any chance a link to their cya? All I see is the liquid on the wally site. I can get 4 lbs from Leslie's for $24 if need be $27 at Lowes.
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Wally word didn't have any granulated or powder cya. I ended up getting liquid conditioner from Leslie's and will order dry cya online.
    Added my 69 oz of liq conditioner and running the pump for 4 hrs. How soon can I add my 15 Oz of bleach?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    PH test reas approx 7.8 maybe a tad higher
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
  20. Back To Top    #20
    May 2013
    Bay City, Michigan
    283
    You can add bleach anytime now.....liquid stabilizer is already mixed in now...so treat your CYA as whatever level pool math said it would get you to from here on out. Don't know your gallons so I can't even look.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
