Results 1 to 7 of 7
Thread: Pool Math Jug size?
    Dec 2012
    Orlando, FL
    28
    Pool Math Jug size?
    Hello,
    So I have the 2.5 Gallon Chlorine Jugs and Pool Math's largest jug size is 182oz. I thought the 2.5's were pretty common outside of box store bleach. At my local Leslies I can usually get my 2.5's filled 2 for $8. I would love Pool Math to be able to tell me how many jugs I need to use to chlorinate to SLAM but it would need a 320oz option. I am good enough at math to do my own calculations but it would be nice if Pool Math could show me quickly.
    Regards,
    Brian
    16'x35' Gunite/Marsite Kidney shaped 12500 Gal,Old (read Original) Sta-Rite TXC-75 75sqft Cartridge (Now a Single cartridge replacement, used to be two separate carts one 50sqft and one 25sqft stacked), Built with the house in 1989
    38,268
    Re: Pool Math Jug size?
    Welcome to TFP!
    Take the number of oz that PoolMath says you need and divide by 320. That is it.
    Rarely will anyone need to regularly be adding that much to warrant it being on PoolMath.
    Edit, I thought you said you were struggling with the calculation, sorry about misreading it.
    May 2013
    Bay City, Michigan
    283
    Quote Originally Posted by RickyTidwellsMom View Post
    How many JUGS? Plural? What are you doing or what is your CYA where you need to use more than an entire jug at a time. (26FC increase assuming it's 12.5%). Just thinking out loud about how that seems like a lot, even for a pool in need of a SLAM.
    5 gallons for $8, nice find there.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    While Pool Math will not tell you how many 2.5g Carboys to add, in the white box above the FC calculation (to the left of where it says "Mouse over a field for detail") it will tell you how many gallons of your chlorine to use.
    Just change the % field to 10 or 12.5% depending on what you are buying. Then when you set your "Now" and "Target" FC levels the white box will show gallons (if you need that much).
    As a test I set 10%; Now 13.5; Target 50 and it shows "10 gallons or 11 (121 oz) jugs".
    Support the site
    Dec 2012
    Orlando, FL
    28
    Thank you all for the responses, I am fine with working seeing the gallons. I understand that there aren't many times when you would need to add a whole 2.5 gallon carboy but i just thought it odd it wasn't there seeing how they seem to be pretty common in my area at least. My current pool numbers are as follows:
    FC 4
    CC 0
    TA 100
    CH 325
    PH 7.2 (added a touch of acid while washing some old calcium scale from some tiles, will aerate to nudge it up a bit)
    CYA 40 (may try to bump this up to 50ish since I am in Central FL and it has been HOT!!!)
    Regards,
    Brian
    May 2014
    Franklin, NC
    9,184
    I wish I could get the 2.5's here in SC.
    Support the site
    Dec 2012
    Orlando, FL
    28
    Quote Originally Posted by scott.MI View Post
    Yeah scott.MI 2 2.5's for $7.95 is a regular special run around here... sometimes it is 3 2.5's for $9.98
    I feel terrible for some of the people here talking about buying 30-40 1gal jugs to SLAM their pool when I can do it so much easier. It still trips me out that some have to use that much CL, I guess because I can't really fathom a 24,000-30,000gal pool for a normal residence. Heck my dad and my best friend have big pools and they are only 18k and 20k respectively. When I bought my house, it had been sitting for 2 years as a foreclosure, needless to say it was low on water and a swamp! I filled it during the winter so the algae was mostly dormant and since there wasn't going to be much CYA in it from the 2 years of rain dilution the CL in my city fill water actually started killing the algae without any extra from me. I did however put in a whole 2.5 gallons, brush and clean the filter about 4 times that day and by the next day it was cloudy but blue. I put another gallon of CL in the next day and brushed and cleaned the filter 4 more times. By day 2 it was almost clear and the tests from the pool store (no kit at the time and before I found TFP) were coming in line with where it should be. I kept adding a little as needed and it finally was balanced. So I think I used maybe 10-15gal of CL to get it right and then maintained after that. I found out that I had a leak and was determined to not dump a bunch of money in Chemistry down the drain (pun intended) so I let it go for almost 2 years only bringing it back when we had a party or something to let people swim. I have just now found and fixed the leak and my current numbers were posted up a few posts in this thread.
    -Brian
    Last edited by RickyTidwellsMom; 06-30-2014 at 11:41 AM. Reason: I looked back at my paperwork and the 3 Jug specials are better pricing than I originally thought
