Results 1 to 7 of 7
Thread: Help CYA is high
    Sep 2013
    San Diego, CA
    12
    Help CYA is high
    Hello,
    I did a TF-100 test and my values are as follows:
    pH = 7.8
    FC= 11 ppm
    CC= 0 ppm
    TA= 160
    CH= 480
    CYA = 90
    The test kit indicates that CYA shld be between 30-80. How shld I get my CYA down? Please let me know. Thanks in advance for all your help.
    Sincerely,
    Aruna
    26,000 gallons; cartridge filter; IG plaster; 1hp pump that runs at 95% in the morning and lower in the evening
    Casey's Avatar
    SW PA
    10,428
    Re: Help CYA is high
    You can get your CYA down one way and that is with water replacement.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I see a partial drain and refill in your very near future. Water replacement or reverse osmosis are the only methods to lower your CYA.
    Sep 2013
    San Diego, CA
    12
    Thank you so much for following up. How will I know how much of a drain to do--1/3?1/2? how much wld it cost?
    Also, I live in southern California where temperatures right now are soaring, we also have a pool cover.
    The water is pretty hot with the pool heater so we have turned the heater off. Does the heat have any role with the hight CYA levels.
    I should also report I don't have any algae in the pool. We brush the pool couple of times and use it almost everyday.
    Also for future should I move to liquid chlorine instead of the pucks
    Thanks in advance for your insights.
    Aruna
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    You're in one of two areas in the US where reverse osmosis is available. So spend the money on that, or drain and replace some.
    Is your pool clear or green? If clear, you can maintain it with that high CYA and slowly lower the CYA by draining a few inches a week and using it one the lawn. If green, grit your teeth and replace a whole bunch right now. R/O won't work until the green is gone, and the cost of the bleach you'll need will be more than the cost of the water. Call your water company - sometimes they drop the tiered rates for a pool fillup.
    Sep 2013
    San Diego, CA
    12
    Thank you. My pool is clear, so I am thinking of going with reverse osmosis. Thanks again for the feedback.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Quote Originally Posted by aru_25 View Post
    Aruna
    How to Chlorinate Your Pool
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
