Thread: Hayward H400fd showing PF error code
    May 2014
    Fort Worth, TX
    6
    I have a Hayward H400FD heater that is throwing a PF error code which is supposed to indicate a wiring/low voltage error. It's wired 240v so the 120v reverse polarity isn't an issue. I have tested line to line and get 240v. I have tested line to ground and get 120v and 119.5v. So from what I can tell it should be working. Anybody out there have any ideas about what to look at next?
    Thanks in advance.
    20k(?) IG plaster, Hayward DE6020, 2.0HP Hayward Tristar, build year 1998, attached raised spa, Hayward Universal H-Series Low NOx heater, aux pump, TFTestkits
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Re: Hayward H400fd showing PF error code
    If everything checks out as you say, then the only other thing is the field wiring panel, FDXLFWP1930.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Did you find out what the cause was? I have the same issue.
