Thread: SWG Salt Level versus Strips/Reagents
    Jun 2014
    860
    Does anyone have good data on the salt level output as read from an SWG versus what they see in strips or reagents? Also, anyone have a feel for AquaChek strips (I have these) versus Taylor reagents (I like titration/colorimetry better)? One better than the other or about the same?
    I'm only just starting to keep records on my IC-40 and my SWG is always reading several hundred ppm above what the strips say. I think this is a common problem as SWG's can only measure the conductivity of the water passing through them which is how they calculate the salt level, but I was hoping folks with Pentair IC's and other vendors SWG systems might chime in...
    And, this is advanced stuff, but I was wondering if anyone knew how to hack into the Pentair controls to see instantaneous output of the salt level from the IC40 as opposed to what I'm sure is some moving average value displayed in the Diagnostics menu.
    38,475
    Re: SWG Salt Level versus Strips/Reagents
    My always reads a around 400 below the salt drop test. There is no data as every pool is different. Just keep records.
    Jul 2011
    phoenix
    133
    mine reads 100 less then the taylor salt drop test.
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    None of the available salt tests, including the ones on the SWGs, are better than +-400, so some variation in the readings are to be expected.
    Jun 2014
    860
    Quote Originally Posted by JasonLion View Post
    Wow, that's pretty bad as far as a test goes. At 3400ppm recommended for the IC40, that's a +/-10% variation in reading. But I guess that says that the SWCG process is pretty good as it seems to work efficiently over a wide salt concentration range...(called being "idiot proof" )
    I'll just keep good records, use up my AquaChek strips and switch over to the Taylor reagents after that.
