Thread: What CH level will cause cloudiness?
    Jun 2013
    Newcastle, Oklahoma
    508
    water not as clear as it normally is.
    FC 4 this morning. added 60 oz to bring to 6 which is target.
    CC 0
    TA 70
    pH 7.4
    just to make sure, even though my FC has never dropped below 3 ppm and my pool consumes 2-3 ppm per day depending on bather load, im going to do the OCLT tonight and make sure its not an organic issue. i doubt it though.
    I havent done a CH test in awhile, but it was 150ppm last time. im going to do it in the morning. CH is the one test I only run once a month since i have a vinyl pool and the level is always relatively low.
    at what level does calcium cloudiness occur?
    i may just be nit-picking my pool too....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: What CH level will cause cloudiness?
    I know that my last year my pool was clear enough to see that the screws on the main drain cover were Philips head through eight feet of water even though the CH was over 1000.
    Jun 2013
    Newcastle, Oklahoma
    508
    okay. well, i SERIOUSLY doubt that my CH is that high. my pool is not that clear. it is in some areas, but not others like the deep middle. dang, I may have dropped the ball somewhere. I have been distracted here lately doing the concrete decking and all, trying to get this pool done. Ill know tomorrow morning when I complete OCLT. if it is over 1 ppm Ill SLAM the ever loving heck out of it.
    i have had to vac it alot lately due to dirt getting in pool. (construction) wonder if its stirred up dirt causing cloudiness. it should settle though.... unless barracuda vac is stirring it up instead of suctioning it out...
    Mar 2007
    San Rafael, CA USA
    12,082
    It's the combination of pH, TA and CH that over-saturate the water with calcium carbonate and can cause cloudiness though usually scale or cloudiness aren't seen until the CSI is +0.7 or more, but under some conditions (mostly in hot tubs) one might see issues at +0.3. This isn't your situation.
