Results 1 to 12 of 12
Thread: Sand Filter Problems
    What's up everyone!
    So here is the deal, I shut off the Sand Filter at night and turn it back on in the morning. Upon. Startup, I notice the return lines are spraying out a bit cloudy water for awhile, taking my previously sparkling water from the SLAM to slightly cloudy.
    If I leave the pump on 24/7 the pool stays clear. But when I try and save the planet and conserve energy by shutting the pump down at night I get a slightly cloudy pool!
    So what's the dealey O?
    Using Tapatalk
    May 2013
    North East Ohio
    959
    Re: Sand Filter Problems
    Need way more info....you know the drill, can you post your test results
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    38,371
    When was the last time you Deep Cleaned your Sand Filter?
    This is the first season with the filter, haven't had to deep clean, just BW.
    Water chemistry is irrelevant for why my filter is dispersing dirty water after being off all night.
    Using Tapatalk
    38,371
    Well, either there is a problem in the filter (laterals cracked, separated or too little or channeled sand) or in the backwash valve (leaking seal) or you pump is too big for your filter (you have not posted any pool info).
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
    I have a ball valve after my pump outlet, could I close that, say 60% and slowly open it, and that could help?
    20x40 IG Vinyl, Hayward Sand filter, Built fall of 2013, Single Speed Pentair Pump, Southwest Part of MI
    Using Tapatalk
    38,371
    Still no idea of the pump model/size or the filter model/size
    Yeah sorry, here ya go...
    20x40 IG Vinyl 35k gal, Hayward 24" Sand filter, Built fall of 2013, Single Speed Jandy 1.5hp Pump, Southwest Part of MI
    Using Tapatalk
    Using Tapatalk
    One thing I am worried about is that when I built it, I used 1.5" PVC, if I had to do over I would change to 2", but no going back on that now :/
    Using Tapatalk
    38,371
    I would not think that your pump would be too big for that filter. The smaller pipe is adding head loss which is lowering the flow rate ... so that would not be a contributing factor either.
    Did you use normal pool sand?
    I'm not sure what the Sand was exactly, bought it from the pool store. I do remember thinking that it looked a little coarse
    Using Tapatalk
