Thread: Bleach listed % or yield % for calculator?
    golfinglenn's Avatar
    Jul 2013
    Springfield, OR
    96
    This was brought up in another thread and I thought I would ask it here since I am the curious type. I did a search and didn't find the answer.
    The jug of bleach that I use lists the % as 8.25, but under the ingredients list is an asterisk that states that the available chlorine is 7.85%. I have been using that number in the calculator to figure out how much CL to add to hit my target level. Is this correct or should I be using the 8.25%, and the calculator is already compensating for the lower yield?
    Glenn
    6500 gal above ground Doughboy with 200lb sand filter and solar panel heater. Converted from Baqua to BBB and never looking back!!
    38,237
    Re: Bleach listed % or yield % for calculator?
    Use the 8.25% number in PoolMath.
