Results 1 to 18 of 18
Thread: No Chlorine
    No Chlorine
    Folks,
    Having read some links here, I know I need to go away and do some further testing before bugging you too much. However....can someone give me just a bullet list of things that can eat chlorine and cause a zero read out. At first I thought it was old test chemicals but am getting same with a new test kit. (not strips). Pool has be fine for years...but this year....Mustard algae (anyone else suffering in the Houston area with this problem so early in the season and a completely 'white' test water sample after the drops are added to the test sample.?
    Here's my latest test samples.
    All pool water - Clear (white), no pink whatsoever.
    1/2 pool, 1/2 bottled spring water - Clear, no pink whatsoever.
    All tap - 1CL / 2Br
    1/2 pool, 1/2 tap - .5CL / 1 Br.
    I'm using my standard amount of Leslies' pool pucks and put 2 lbs of shock in about 10 days ago.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: No Chlorine
    What test kit are you using?
    Did it come with a CYA test?
    Before anyone can really help you, we need to know these things.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: No Chlorine
    I am sorry to say that the bullet list will not help now. Regardless of what the culprit is, SLAM is the answer. But, depending on the test results, we may suggest a drain/refill dance first!
    So, before we can really help, we need a full set of test results, please
    FC
    CC
    pH
    TA
    CH
    CYA
    You're done SLAMing when:
    30,432
    Re: No Chlorine
    There actually is sort of a "bullet" list that is often overlooked but is essential in understanding your pool water.
    That list has two items....
    1. UV from the sun
    2. Organics in your pool water.
    Those are the only two things that consume chlorine.......nothing else.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: No Chlorine
    A member here for 4 years still using Leslies' pool pucks & shock
    I would like to see test results also, especially CYA.
    Support the site
    Re: No Chlorine
    1. UV from the sun
    And Organics will include leaves, pollen, swim suits, body oils, sweat, hair, and so on.
    Re: No Chlorine
    OK, thanks I'll get a full test. As I recall in May....I think the CYA and CH were very naughty indeed, but I'll re-check.
    Thanks
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: No Chlorine
    I take it you don't have your own test kit, and that you are still relying on Leslie's for your testing.
    With that, you can count on having recurrences of cloudiness and algae.
    Very strongly recommended that you purchase your own kit, either the TF-100 or K-2006. I can guarantee the it will pay for itself in one season.
    Re: No Chlorine
    Quote Originally Posted by Charlie_R View Post
    No, I do have the kits. One of them covers all the tests and has the Water Balancer wheel in it. It's a few years old, hence I thought the chlorine test results were down to old chemicals, so I bought a new basic kit for free chlorine and PH. It's been a while since I had any algae problems, to the point where I found a part used bottle of algaecide in my garage and I can't recall when I bought it, so everything has been fine for years....just all gone to pot this season. I do know my CH and CYA are up from several years ago, but I'll retest and post back.
    Thanks
    38,546
    Re: No Chlorine
    Sounds like you still need order one of the recommended test kits.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: No Chlorine
    Or at least new reagents. Get them at the same place: http://TFtestkits.net
    Re: No Chlorine
    OK, hopefully I've fixed the mustard algae problem. I went with a couple of packs of jacks yellow out, a little bit each week, copious amounts of pool wall scrubbing and I'm trying Clorox brand pool shock. Also cut over to Clorox bleach. I've got the free chlorine at 3 ppm now and all looks ok so far. The local Kroger now has a range of Clorox pool supplies in stock, so we'll see how that goes.
    Thanks
    Re: No Chlorine
    I did get rid of all my yellow algae and spots of black algae. To anyone having problems, try Clorox pool shock and some ordinary bleach. If you have a spa connected to the pool, try dumping the bleach into the spa with the pump off. So let the bleach sit in the spa overnight, my theory is that a lot of this algae starts life in the shallower and thus warmer temps of the spa. I've got my chlorine levels back and stable and all algae has gone.
    Thanks
    38,546
    Re: No Chlorine
    Adding any chemicals without the pump running is not recommended by TFP.
    Also, there is nothing special about "Clorox pool shock"
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: No Chlorine
    It isn't a good idea to blindly add products without proper testing (with a recommended test kit). Given the products you are using, I'm willing to bet your CYA is sky high. A clear pool doesn't mean a sanitized pool.
    I'm sure you could cut your pool chemical costs if you really switch to the TFP methods. If you are going to keep using pool store "shock" and other magic potions, expect to pay for it in time and $$$.
    If you use a recommended test kit, test regularly, make adjustments as needed, you won't have to battle algae again.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Sep 2014
    Dawson MN
    13
    Re: No Chlorine
    I have switched to Taylor 2006 test kit and I think that it has saved me alot of headaches as far as accuracy in test results. I totally recommend it to you, easy to use, the directions are explicit. If you can count you can use this test kit with ease.
    Dawson, MN.,135,000 gallon indoor pool with a sand filter system and a auto-chem feed. I believe it is a BECSYS 3 feeder. The pool is located in a High School and only open from Nov.- Apr. It is also and IG pool I use the Taylor 2006 test kit and love it
    Re: No Chlorine
    I thought the Clorox Pool shock was a different chemical than that supplied by Leslie's etc? Anyway, I have good stable chlorine readings, clear pool water and no algae.
    Thanks
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: No Chlorine
    Quote Originally Posted by iceflow View Post
    Per the MSDS, they all have the same active ingredient of trichlor which is one of the types of chlorine that includes CYA, but at different strengths.
    CLOROX POOL & SPA / SHOCK QUICK / 10: Has 30 to 60% Trichlor
    CLOROX POOL & SPA SUPER / SHOCK QUICK / 20: Has 40 to 70% Trichlor
    Leslie's Super Shock has > 70% of Trichlor.
    Leslie's Gensis Shock has around 63% of Trichlor (I couldn't find the MSDS for this one).
    Karen
