Thread: Debris floating on pool surface
    Fort Worth, TX
    83
    I know my question does not fit under pool chemistry, but I couldn't find a category for it.
    I have debris floating on the pool surface. It won't work it's way down to the skimmer.
    The skimmer is working fine and has plenty of suction. Weir door is working properly.
    I suspect I need to adjust the return jets. I know how to adjust the eyeballs, but I don't know what attitude to adjust them to.
    My pool is rectangular. The skimmer is at one end of the pool. I have two jets at each end of one of the long sides (within about 5' of the ends).
    I have a third jet on the other long side, close to the center.
    Should I direct them all to the skimmer? That's what I have done and it doesn't work.
    Any help is appreciated.
    Thanks
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Debris floating on pool surface
    Trial and error and pointing them in the same direction with maybe angling them up a little closer to the surface of the water is about all you can do. Filter pressure good? If so, you can always try putting in a smaller diameter eyeball to increase the power of the flow coming out of the returns. It is also most helpful if your skimmer is located on the down wind side of the pool.
    Fort Worth, TX
    83
    The filter pressure is good. The wind varies in direction.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,028
    For skimming, its best to move the eyeballs around to try and get the water on the surface flowing in a circular pattern.
    Divin Dave,
    30,432
    My skimmers aren't great at that, either. It's one of those things I can't completely resolve.
    You will get better with trial and error but, meanwhile, it is MORE important that you scoop the debris out of your pool manually to keep it as clean as possible.
    Fort Worth, TX
    83
    I've been keeping it cleaned out with a net.
    The hotter it gets the more I want that skimmer to do it's job.
