Thread: intex salt water system?
    Hi I have an INtex quick set pool..I think it is 18' it is one of the biggest they sell any way, I don't feel like the filter it came with is adaqute and I have been looking at the salt water system, what are others thought on this?
    _____________________
    Jason M
    11k gallons,
    Lomart Whispering Winds AG (15 x 30 oval)
    Waterway Supreme Hi-Flo 1.5 HP pump,
    Waterway Clearwater II Cartridge Filter (120 GPM max flow),
    1 sidewall skimmer / 1 return,
    Waterco 80k BTU Heat Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: intex salt water system?
    This thread may interest you....
    intex-above-ground-tell-me-about-it-t7905.html
    All about other intex owners and their pool issues, members on this forum.
    Quote Originally Posted by frustratedpoolmom
    while that was interesting, no one talked about a salt water system..
    Jason M
    11k gallons,
    tootie's Avatar
    Apr 2008
    NC
    46
    24' x52" Intex metal frame
    Pentair sand dollar SD60
    Original pump 2500gph
    "5 years of BBB, and loving it"
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Converting to a SWCG isn't going to improve the filtering of the water. If you think the filter's inadequate (and that's a common theme with the Intex pools), your only recourse is to replace your filter/pump with a bigger model. You can stay with the Intex models, or try to rig your pool to use a sand filter and possibly a 1/2 hp pump. There have been some posters on here who have had success doing it either way; easiest would be to upgrade to a bigger Intex model.
    EDIT: BTW, I have an Intex SWCG, and it maintains the FC level very well on my AGP. Once you get your pump/filtration issue worked out, the SWCG would be a nice addition to your pool.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
