Results 1 to 8 of 8
Thread: Green water after adding algaecide just filled pool
    petrocomical's Avatar
    Apr 2013
    Baton Rouge Louisiana
    16
    Ok...first off I'm still a newb. I just had a new IG liner installed and used city water the same as last time. My PH was very high at about a 9 and my chlorine was 0 for some reason I thought it would be a good idea to add some Algecide that I've used before from the blue box store that is a preventative. As soon as I started to bring my PH down with Muratic my pool turned green. Clear but very green. I don't want to get pool stored so I came here first.
    My readings now
    FC 3
    CYA 0-10 and building ( stocking is in the skimmer full of CYA )
    CC 0
    PH 7.2 - 7.4
    TA 120
    CH ( have not tested )
    (Aqua chem) algae eliminator is the brand and the ingredients are below:
    Alkyl (50% C14, 40% C12, 10% C16) is listed first
    then Active ingredients dimethyl benzyl ammonium chloride 50%
    other ingredients 50%
    I've used the product before and had good results pool had a very minor green algae bloom and I kept my FC at 5 and one bottle and bam blue sparkly pool. But the last time I used it my water was balanced also.
    Again the water is clear but green but there is a film or sheen on the top that's a brownish color.
    Any advise please?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Green water after adding algaecide just filled pool
    It could just be Iron. It's common for pools to turn green when the chlorine hits the water. It usually goes away in a day or two. Concentrate on getting everything balanced and be patient. If the water is crystal clear but just tinted but not cloudy and it doesn't go away in a couple days, then you'll need a metal sequestrant.
    Apr 2013
    16
    I took a water sample to the pool store and their numbers and mine match up fairly close my TA went down prolly from the muratic addition and my CYA went up but I added that.
    PH 7.4
    FC 1
    CH 150
    CYA 40
    TA 110
    Phosphates 500
    They recommended raising my calcium hardness and a thing of phosfree...they did however recommend giving it 3-4 days with balanced water and see what happens.
    38,364
    What kind of Pool do you have? Your signature is blank.
    Forget about phosphates.
    Apr 2013
    16
    Updated sig...thanks for the replies I'm going to keep balance for a few days and see what happens then look to metal sequestrant.
    30K IG vinyl kidney shaped, Pentair Tagelus 60, Hayward 1Hp superpump, Hayward booster pump
    38,364
    Your FC is too low for your CYA level, so you are not balanced.
    With a vinyl pool, there is no reason to add CH.
    Apr 2013
    16
    Thanks for the reply i just finished my fill working on getting the FC up to 4-5 now
    Apr 2013
    16
    took 3 days but cleared right up thanks Richard320!
