Hello Pool Pro's,
Brand new to forum and BBB method.
My old 1hp pump was leaking, so I took it to a pool store to replace the seals and the impeller was cracked. They had to order a new impeller which took 5 days and the pump still leaked when i hooked it back up. So I replaced my old DE filter and pump with a sand/micromatic media filter/pump combo. The pool was a swamp by this time. I found this site, and read and got some pool schooling so now the pool is clear enough to see the bottom. I just tested the pool water with new TF-100 kit, just got the test kit so haven't done an OCLT
FC-0
TC- 0
CH- NOT TESTED
CYA- <20
TA- 70
pH- 7.8
I don't want to wait another week to use this money/life sucking pool. I will buy the liquid stabilizer. Can I add the stabilizer and then start the SLAMing? Or do I need to wait 4 hours to start SLAMing? Thanks
FC-0
TC- 0
CH- NOT TESTED
CYA- <20
TA- 70
pH- 7.8
