Thread: Cloudy pool need some "clarification" on what to add
    May 2014
    New Haven, KY
    17
    Hello all,
    My pool has been doing great but I just went out of town for a week for work. Had my girlfriend taking care of the pool now it was pretty green and very cloudy. I have been slamming it all week and have vacuumed most of the algae out bit it's still cloudy. I think I need to lower the ph to clear it up?
    Here are my test results
    FC 10-14 since Friday night
    PH 8.0
    alkalinity 130
    Cya 25
    Will lowering the ph help the cloudy water?
    30' Above Ground Pool-approximate 4' deep 20,000 gallons (Watson's)-lots of trees
    1.5 HP motor (High 16amp/Low 4.8amp) Waterway pump, 175 SQ FT Cartridge Filter
    AQUA SMARTE Chlorine/mineral System - not active
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Cloudy pool need some "clarification" on what to add
    Don't mess with the pH.
    When FC is above 10, the pH reagent reacts and reads falsely high.
    PH at 8.0 is a little high, but not normally high enough to cause cloudy water (unless your CH level is very high). Plus the PH might actually be a little lower than it measures. FC between 10 and 15 can cause small errors in the PH test results.
    How has your filter pressure been behaving?
    May 2014
    New Haven, KY
    17
    It's been looking normal. I have been cleaning the filter off very frequently.
    Then the filter is working. As long as you see any water clarity improvement from day to day you should just give the filter time to do it's job.
