Results 1 to 9 of 9
Thread: Cloudy pool
    Cloudy pool
    I have had trouble with my intex quick set pool this year..I can't seem to get the chlorine up in it..here are the numbers th 0-100 fc 1/2-2/4 ph 7.8 ta 120-180 cya 0-30/50
    I shocked it last night to try and increase the chlorine, but now it is cloudy, ubtil a few days ago it was chrystal clear..it started to get a tad bit cloudy now I can hardly see the bottom and it is only 3-4 feet deep!
    What should my next step be?
    _____________________
    Jason M
    11k gallons,
    Lomart Whispering Winds AG (15 x 30 oval)
    Waterway Supreme Hi-Flo 1.5 HP pump,
    Waterway Clearwater II Cartridge Filter (120 GPM max flow),
    1 sidewall skimmer / 1 return,
    Waterco 80k BTU Heat Pump
    mbar's Avatar
    Ashland PA
    257
    Re: Cloudy pool
    First, you have no cya - which will let the sun eat your chlorine up almost as soon as the sun hits it! It is no wonder you can't hold chlorine. You need to get some stabilizer in there or use stabilized chlorine (like trichlor pucks) right away. Stabilizer doesn't show up right away in the test (you should get a test kit and not count on test strips). You can put stabilizer in a sock and let it dissolve. I recommend that you read the pool school posts on this site. You need to shock the water - take the chlorine up to 10ppms and let it drift back down. Until you get some stabilizer in the water you will have to add chlorine whenever it gets below 3ppms until you have enough cya (stabilizer) in the water to hold the chlorine. Your water is cloudy because it is on the brink of an algae outbreak, and by adding chlorine you have kept it at bay - it was just not high enough to kill all of the algae, that is why you have to shock the water.
    16x33 fiberglass pool sand filter
    Re: Cloudy pool
    I have read the pool school, and I understand that I should be using the BBB method but I have a bunch of pucks already, so I want to use them before going to the BBB..if I use pucks will I also need to add stabalizer? Or should that be enough?
    Jason M
    11k gallons,
    Re: Cloudy pool
    If you are using trichlor pucks and have the pump running during the day there is not normally any need to add stabilizer (CYA).
    It is very difficult to guess what might be going on with only approximate test results from test strips.
    I am assuming the water turned cloudy and you had trouble maintaing chlorine levels before you shocked.
    Killing algae requires maintaining high FC levels for a couple of days. A single addition of chlorine will only work if you catch it very early.
    Jun 2008
    Knoxville, TN
    83
    Re: Cloudy pool
    You'll hear it here in every thread like this and they're exactly right. Get a good test kit that lets you test high chlorine levels. With that, you can start shocking the right way and not just blindly dump bleach in there. I wasted 7-10 days before I got the test kit. Once I had it, I killed what was in there in about 4 days and had the water clear within a few days after that. Took me two weeks overall but should've only taken one.
    Once you get the test kit, shock the heck out of it. Keep it at shock level or just above. Don't let it drift below -- get it there and keep it there until you stop losing chlorine overnight.
    Steve
    24' Round Above-Ground Pool, 13500 Gallons
    Triton Meteor Sand Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy pool
    Quote Originally Posted by ssmith1627
    Steve
    Jun 2008
    Knoxville, TN
    83
    Re: Cloudy pool
    FPM -- I don't know a thing but I'm good at repeating what you guys told me. And I do so because it WORKED....hehe. I'm here for moral support if nothing else. I was in their shoes not a month ago !
    Steve
    Re: Cloudy pool
    I shocked again tonight, as well as added a big puck, (3") I will check it in the am to see where the levels are. I know I should get a good test kit, and I will but for now I am going to have to rely on the test strips. I also ordered a bigger filter, I am using the one that came with the pool, and I just don't think it is big enough..I went for the 2500 GHP modle from intex.
    Jason M
    11k gallons,
    Jun 2008
    Knoxville, TN
    83
    Re: Cloudy pool
    Even just the FAS/DPD chlorine test would be a good start. It's about $25 and you can have it in 2-3 days. Well worth the money to keep you from wasting bleach and not making any progress.
    Steve
