You have a lot of hose clamps. Any one of those could be leaking air which may explain the air in the returns. Those are union valves correct? Those too are subject to air leaks.
Does the heater connect to the "hot" and "cold" lines?
To use the heater, do you shut off the valve in the middle and turn both of the other two on?
Not sure what type of valves they are.
That picture was a little dated, it was too cold to have the heater on, you are correct I would shut off the blade in the middle and turn those other two on.
