Thread: Frank from New Brunswick
    Jun 2014
    St. Stephen, New Brunswick Canada
    2
    Just found this site and I am loving what I see. We have had our pool for about 12 years and it has been "mostly" trouble-free; until last year. When we opened the pool we had a milky-like suspension in the pool. If we shut the pump off at night, the water was crystal clear in the morning; within minutes of restarting the pump, the water clouded back up. Long story short, we went to 3 different "pool experts" and tried their fixes which included spending in the neighbourhood of $1000 on chemicals............. no fix. This year, screw the experts and we will try and manage the pool ourselves with help from forums such as this. Due to the cold wet spring we have had, we are just getting the pool opened up this weekend; gonna be a short summer.
    24" round above ground vinyl pool
    Hayward SP2295 1.5 HP pump
    Hayward 24" Pro Series Sand filter
    Pool is about 12 years old with a disassembly then reassembly two years ago
    AquaPro Pro 500 heater
    Casey's Avatar
    SW PA
    10,428
    Re: Frank from New Brunswick
    Welcome!
    Search the forums for a dealer to ship you a K2006 test kit! You will need one!!! It's the best kit you can find.
    Read the ABC's of Pool Water Chemistry and you should be well on your way!
    Hope you enjoy TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to TFP
    Glad you found us, and you will be too
    You're done SLAMing when:
