Results 1 to 13 of 13
Thread: Finally filling the pool tomorrow - startup questions
    jmcdtucson's Avatar
    Jun 2014
    317
    The ground is level, the pavers are flush, now it's time to set up and fill the pool.
    Here's my question:
    I have Intex sand pump and SWG and the following supplies:
    200 lbs. of salt
    Muriatic acid (our water is 7.8 PH)
    CYA
    #20 silica sand
    #1 is there anything else I need?
    #2 It sounds like my first job is to adjust the PH and add the salt. Does this sound right?
    It's supposed to be 109 degrees by Tuesday so I'm a little excited to get this project done!!!!!
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Casey's Avatar
    SW PA
    10,457
    Re: Finally filling the pool tomorrow - startup questions
    I would order a test kit here Test Kit Comparison. You are going to need one!!! The TF100 is the best kit for the money as you will get more reagents than the K2006 offers. It will last you a few seasons if you store it right and keep it out of the sun.
    I would also recommend you reading ABC's of Pool Water Chemistry and if you have any questions, just ask! We will help you!
    jmcdtucson's Avatar
    Jun 2014
    317
    Thanks! I have the TF100 test kit. I will read the Water Chemistry page.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Casey's Avatar
    SW PA
    10,457
    The test kit is great! There are a few links in Pool School that you could benefit from. Just go down the list and read them and you'll be golden. If you need a question asked, we're open 24/7!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    You need bleach. The salt is supposed to dissolve for 24 hours before you can start the SWG.
    I suggest you hold Diamond Day. Get everything balanced as a bleach pool, and then add the salt. Post #5 explains it.
    jmcdtucson's Avatar
    Jun 2014
    317
    Thanks. That makes sense and is so helpful. So can you explain how much bleach I should add?
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Casey's Avatar
    SW PA
    10,457
    jmcdtucson's Avatar
    Jun 2014
    317
    Poolmath says to add 0 oz. of bleach
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    You have to put in your gallons and goals....play around with pool math
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Casey's Avatar
    SW PA
    10,457
    You have a NOW column and a Target column. Your now, is what your FC is now and the TARGET is where you want it to be.
    jmcdtucson's Avatar
    Jun 2014
    317
    Duh, yes, sorry for the stupid comment. I'm starting to get it.
    Hats off to the creator of POOL MATH and the people who answer all the newbie question.
    So I have a couple of questions now:
    #1 I'm curious why we add bleach first when the SWG will produce chlorine. Is it to get the chlorine up faster to reduce the chance of trouble?
    #2 Do these steps look somewhat right?
    1. Turn on pump. SWG stays off
    2. Dissolve salt (210 lbs. is recommended, test my water first and use pool math to get to 3000)
    3. Put in CYA per manufacturer reccomendation (2.1 lbs. recommended n the SWG manual - 2.1 lbs. but test and use pool math)
    4. Add bleach to get to target FC using the chart here:
    http://www.troublefreepool.com/conte...art-slam-shock
    5. Test and if necessary adjust PH to approx. 7.5-7.8
    6. After 24 hrs., turn on SWG after salt is right and run pump/SWG at recommended intervals
    Finally, test everything and adjust to recommended levels:
    http://www.troublefreepool.com/conte...mmended-levels
    Again, thanks!
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    jmcdtucson's Avatar
    Jun 2014
    317
    We did this. The kids had a blast and dissolved all my salt for me.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Quote Originally Posted by jmcdtucson View Post
    A few days late to the party, you probably already have it up and going, but.... You add bleach first because the SWG is designed to maintain the Cl level, not bring it up from 0 or bring it up and large amount.
    Again, thanks!
    If you did all that, I'm sure all is well. How is it?
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
