Results 1 to 8 of 8
Thread: newbie needing help
    Jun 2014
    Atlanta, ga
    26
    newbie needing help
    FC - free chlorine 1 ppm
    CC = Combined Chloramines 0
    TC= total chlorine 1
    PH 8.2
    TA - Total alkalinty 70
    CH - calcium hardness 125 ppm
    CYA - cyanuric acid...aka stabilizer/conditioner 50
    I tested my pool about 3 weeks ago and the CYA was 150 or more. I drained the pool about half way and it was around 100. So, I had to drain again. I drained it and left about 1/4 of the water. I just tested the CYA and its at 50!!!!! Now that I have that taken care of, what do I need to do? I'm a little lost. My readings are above. I used the TF-100 test kit.
    According to the pool calculator I have to add the following:
    1) 75 oz of 6% bleach. The beach that I bough says 8.25% Sodium Hypochlorite. Do I add 75 oz of this bleach?
    2) 22 oz of muriatic acid
    3) 127 oz baking soda
    4) 253 oz calcium chloride. Is this the same thing as Calcium Hardness Increaser? I bought it at Home Depot. I couldn't find calcium chloride anywhere.
    My test kit did not come with a Borate test. Do I need to purchase one? If so, where do you recommend?
    My last question. How should I add all these chemicals? All at the same time or space them out? Any recommendation would be awesome.
    18K gal, IG Gunite, Sand Filter, TF-100 test kit
    Casey's Avatar
    SW PA
    10,421
    Re: newbie needing help
    Disregard the TA right now.
    You can play with that later.
    Add the MA to get the pH down.
    Wait 15 minutes while circulating and retest and adjust again if necessary.
    Add the Bleach to get the FC up.
    Test after 30 minutes of circulating. If you've hit your mark, continue on.
    Then add the CH.
    How does your water look?
    Have you read ABC's of Pool Water Chemistry yet?
    Jun 2014
    Atlanta, ga
    26
    Thanks. The water is a little cloudy but not bad. Yes, I did read that. I'm just hesitant with all these chemicals.
    Did I buy the right calcium chloride?
    Casey's Avatar
    SW PA
    10,421
    It should do the job. If your water is cloudy, then maybe you should SLAM the pool. Your FC is really low and I wouldn't be surprised if you were harboring algae spores in the pool. I'd hold off on the Calcium until the pool is clear. Get the pH down and SLAM (pH will read a false high during a SLAM) and brush the pool like mad.
    Jun 2014
    Atlanta, ga
    26
    Got it. Ill give it a try. Thanks
    Jun 2014
    Atlanta, ga
    26
    I read about slamming process in the pool school. I don't understand how much chlorine do I need to add to SLAM my pool. Any suggestions?
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    ABCs of Pool Water Chemistry will give you a great understanding of what each test and chemical is and how it effects your water and the Chlorine/CYA chart will give you a condensed version of all your levels. Pool School is a wealth of information. Good luck!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    SLAM level would be 20 according to Chlorine/CYA chart.
    http://www.troublefreepool.com/conte...art-slam-shock
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
