Results 1 to 19 of 19
Thread: raypak heater not as hot???
    At the beginning of last season the water out of the jets would be really warm and as the season went on not as much. Could this be dirty burners?
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: raypak heater not as hot???
    Take the front cover off and look under inside as it's on and see how the flames look. Dirty burners usually translates to a sooted up heat exchanger. Also pop the top off and see how that heat exchanger looks. If it's full of black soot, then it needs to be cleaned. How is the water flow? How old is the heater?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pop the top off??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    What model and size (BTUs)of heater do you have?
    Paul
    Model is p-r206a-mn-c
    input btu 199500
    output btu 163590
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It should have what is called a pagoda top that comes off. You can then look down inside to see if the heat exchanger is dirty.
    Paul
    And if it is how do I clean it??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    With everything off including the gas, remove the burner tray and then using a hose with a good spray nozzle, spray down thru the top you removed and then spray up under where the burner tray was. Do this a few times until you don't have any more soot coming out.
    Paul
    Like a pic of garden hose to funnel the water?? How do u remove burner tray?
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    A regular nozzle on a garden hose is what you need. As for the burner tray disconnect, There are several screws that hold the tray in place to the bottom of the heater. You have to disconnect the gas line and without seeing how you have it hooked up, I can't tell you exactly how. I would hope there would be a union after the shutoff that you can undo to remove the burner tray.
    Paul
    Can I just rinse it with a garden hose or is that too much water??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You need something with a little force behind.
    Paul
    so an attached garden hose is ok? cause first u were just saying a spray bottle? also i see some people online just vacuuming them??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I never said a spray bottle. I suggested a hose with a spray nozzle on it. I always use a garden hose with a strong spray nozzle to wash it off. Vacuuming is not an viable option. Remove the burner tray and then hose off the heat exchanger from the top and then the underneath. It works great and is the best way to clean the heat exchanger. First do a visual inspection and you should see the soot on the heat exchanger.
    Paul
    So the pagoda top is different from the actual exhaust stack, does the exhaust stack have to removed to get the pagoda top off?
    If the heat exchanger is dirty I can rinse it with the burners still installed correct?
    Also does that mean burners need to be cleaned if heat exchanger is dirty? If so how do I clean those?
    Quote Originally Posted by ps0303 View Post
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Well the best way to clean completely you would remove the entire top off the unit. However, if it's not sooted that bad you can removed the pagoda top and then spray down from there. I would remove the burners as all of that soot could get into the burners and clog them.
    Paul
    Can I vacuum the heat exchanger instead?
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I wouldn't vacuum up soot.
    Paul
    Jun 2012
    western NY
    1,560
    Don't try to vacuum the soot unless you have the proper filter for the vac to do it with. That stuff is finer than flower and will go thru most vacuum filters. As Paul said, take the time to pull the burner tray and hose it down. This is the best way to get them clean.
    Up here in the north we have to do boilers and furnaces every so often if they are not set up right. Being indoors it is difficult to use a hose so we have to use long handled wire brushes and vacuum cleaners. Unfortunately, this does not get all of it out and the problem comes back quicker than if we could get it all out.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
