Thread: Pressure Gauge/Vacuum gauge
    user_unknown's Avatar
    Apr 2014
    Metro Phoenix Arizona
    8
    Does anyone run multiple pressure Gauges and/or a Vacuum gauge?
    I recently had the opportunity to see a very sophisticated Commercial pool equipment room and one of the things I immediately noticed was in addition the the usual pressure gauge on top of the filters, they had installed pressure gauges between the pumps & filter, and also after the filter on the return lines. They also had vacuum gauges installed on the drain plug of every pump. There were also lots of digital gauges and computer screens that were monitoring something as well.
    This pool also appeared to have a very complicated liquid chlorine & acid injection system, maybe the gauges are used somehow for that.
    23,900 gallons, 20'x'40', Midnight Blue Pebble Gunite inground, 2HP Hayward super II(will be replacing with two-speed pump soon), 60SF Hayward D.E.
    Re: Pressure Gauge/Vacuum gauge
    Having several gauges like that can help you quickly narrow down where a pipe blockage is in the system.
