Thread: Installing New Pentair IntelliChlor Chlorine generator
    tndtanaka's Avatar
    May 2014
    Riverside, CA
    14
    Reading the manual prior to installation and came across this. "Do not add any pool water balancing chemicals including salt unless the IECG is turned off." When I add liquid muriatic acid or bleach if I need to help out the swg at any time or more salt how long do you think I should leave it off? I run my pump during the day and add chemicals as needed in the morning. My pump runs 7 hours on low speed and 3 hours on high speed.
    25,000gal, IG, pebble, DE, variable speed, spa, SWG, 10/13 install, 50'x14'
    Re: Installing New Pentair IntelliChlor Chlorine generator
    Don't add any chemicals directly to the skimmer when you have a SWG. But you are fine adding chemicals as we recommend, by pouring slowly in front of a return jet. By the time they get to the SWG they will be throughly mixed in and there won't be any issues.
