Results 1 to 8 of 8
Thread: Adding CYA to 12' Easyset?
    Jun 2014
    Bend, OR
    13
    Received the CYA, I know I need to put it in a sock and place in front of the return jet, but one question...like a woman's nylon sock or a regular cotton sock? I should start slow with the CYA no? It's only about 1400 gal, brand new fill few days ago.
    PH 7.5
    CL 5'ish
    Thanks in advance!
    I've been all over pool school but it never mentions what type of sock? Unless I missed
    AG EasySet 12x30 1438? gal
    Standard equipment A type filter
    Pool build 6/22/2014?
    Re: Adding CYA to 12' Easyset?
    Any kind of sock/stocking without holes is fine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by DaddyGreenJeans View Post
    PH 7.5
    CL 5'ish
    Thanks in advance!
    In your case, I'd just measure out enough to hit the target and add it all at once. Your pool is small enough that if you accidentally overshoot a little, draining of a bit and refilling it will take an hour, not days and days.
    A nylon is more porous, a sock can withstand more abuse, if there are children involved.
    Jun 2014
    Bend, OR
    13
    Perfect thanks guys!
    Jun 2014
    Bend, OR
    13
    One last Q, do I leave the sock in the pool all the time or only when the pump is running?
    Richard320's Avatar
    Jan 2010
    19,007
    Your call. It depends how it's hanging. You don't want it sitting against the wall, since CYA is acidic and it could discolor the liner. If you're worried, set it in a plastic bucket while the pump is off.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Give the sock a squeeze periodically. That will help it dissolve faster.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2014
    Bend, OR
    13
    This is all excellent, thanks a million guys!
