Thread: Extra long Return Jet eyeball fitting?
    Jul 2013
    Long Island, NY
    147
    I need to replace my eyeball fittings since the existing ones don't have enough threads for me to properly direct them. Does anyone know if they make standard 1.5" threaded jet eyeball fittings with more threads?
    Casey's Avatar
    SW PA
    10,442
    Re: Extra long Return Jet eyeball fitting?
    I'm not sure, but hey... anything is possible with PVC fittings and such in the plumbing aisle of the home improvement stores. I modified my eyeball that way because it wasn't directing the water the way I wanted it to. All you can do is try.
    Also, can you please fill out your signature and profile as outlined here What we need to know to answer your questions . It helps us so much to be able to offer your regional support and not have to continually ask you about your pool specs as we can just look at it in your signature. Thank you.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    You can also ditch the eyeball thing and make a 90 degree return jet. It requires a threaded piece that screws into the wall and receives a short piece of pipe just long enough to attach to a 90 degree fitting. I use the full 1.5 inch opening most times which gives plenty of circulation but there is a fitting that reduces that to .75 inch which is what your eye probably is.
    Jul 2013
    Long Island, NY
    147
    I went out and purchased two new standard eyeball fittings which have the eye you can position. Even though there are few threads holding it in, I was able to position them effectively. Thanks all for the responses!
    20x40 in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward Superpump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
