Ideal heater plumbing connection location and equipment required
Jun 24, 2014
22
Montreal QC Canada
I'm trying to figure out if plugging my heater (actually a heat exchanger) is as simple as what I have in mind.
Do I simply need to install 2 three way valves between my chlorinator and the return to the pool? If this is the case, any recommandations concerning the valves? Anything else?
Many thanks.
Just purchased 2 Jandy 3 way valves and wanted general advice prior to gluing. I'm realizing a lot of unions and couplers will be reduced to waste with my new set up because well gluing is a one way street. What is the general consensus on gluing relatively expensive valves? Always use at least x amount of PVC pipe to make sure it'll be possible to reuse them in a different configuration in the future?
Thanks again
