backflushing daily
ggenovez
Active member
May 27, 2012
31
Hi everyone.
I have a 15000 gal salt water pool I'm having trouble with. I have a compupool 16 chlorinator.
I just took apart the DE filter and cleaned it out. It had green slime all over it. Pool is a little green.
After I cleaned it and added 6 lbs of DE it ran fine for a week. Then every time I back flush it, it goes from 14PSI to 25 PSI in 24 hours. The filter is running 24H so I can clean out the murkiness and get the chlorine up but it's not working even though the Chlorinaotr is at 100%. I've cleaned that out as well
My back flush procedure is, backflush for 30 Seconds, filter 30 seconds, and I repeat that for 3-4 times. then add 3 lbs of DE
What am I doing wrong?
Thanks
Your cloudy pol is a chemical problem, not a filter problem. The filter is just another symptom.
We end a full set of test results, but I'm going out on a limb here saying you need a SLAM
:testresults:
I'm going to guess your problems with the SWG before allowed the FC to drop and algae moved in.
