Thread: backflushing daily
    backflushing daily
    Hi everyone.
    I have a 15000 gal salt water pool I'm having trouble with. I have a compupool 16 chlorinator.
    I just took apart the DE filter and cleaned it out. It had green slime all over it. Pool is a little green.
    After I cleaned it and added 6 lbs of DE it ran fine for a week. Then every time I back flush it, it goes from 14PSI to 25 PSI in 24 hours. The filter is running 24H so I can clean out the murkiness and get the chlorine up but it's not working even though the Chlorinaotr is at 100%. I've cleaned that out as well
    My back flush procedure is, backflush for 30 Seconds, filter 30 seconds, and I repeat that for 3-4 times. then add 3 lbs of DE
    What am I doing wrong?
    Thanks
    15,000Gal AG , Plaster, DE, 1.5HP, Compupool SWG
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: backflushing daily
    You are likely not back flushing long enough. You also need to get chlorine in the water via manual addition of Bleach or you are just moving live algae around. Your Filter will continue to clog up pretty quickly.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Your cloudy pol is a chemical problem, not a filter problem. The filter is just another symptom.
    We end a full set of test results, but I'm going out on a limb here saying you need a SLAM
    I'm going to guess your problems with the SWG before allowed the FC to drop and algae moved in.
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Test results?
