Thread: New fill after 3rd leveling move
    Jun 2014
    Granite Falls, NC
    7
    Okay first of all we have moved our pool 3 times so far this summer. The first time it was about 6 inches off. The second time it was about 4 inches off. This time I believe it's between 1&2 inches so I am going to keep it there. However I tested the water and I have a Walmart test kit which I know is not the best but my PH side is purple my chlorine side is a bright yellow see picture below. What do I need to do? View pictures
    1st time pool owner
    Pro-Series 14x42
    Re: New fill after 3rd leveling move
    The FC level is fairly high, too high for the PH test to work correctly.
    There are huge advantages to getting a better test kit. Lacking that, perhaps you could get a set of results from a pool store.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by kjlail View Post
    Just wait.
    If you haven't added any stabilizer, that superhigh FC will go down to a reasonable number within hours and then you can get accurate pH readings. Right now, if someone gets in they might have eye or skin irritation and swimsuits will fade.
    Jun 2014
    Granite Falls, NC
    7
    No stabilizer has been added. And the sun is finally out. Going to wait and check again this evening. Thanks
    1st time pool owner
    Pro-Series 14x42
