Can I assume that if I have had and defeated the yellow Mstrd Algae, that I should now keep my FC at the appropriate Yel/Mstrd Min (7.5) from now on?
Not sure which column on the chart is appropriate for my situation
Also at what FC level does the PH test become invalid,
FC 13 (coming down from shock process)
PH 7.4 (was wild during shock so not sure this is accurate?)
TA 60
CH 70
CYA 50
Water is 88 degrees
Salt is 2900
TA 60
CH 70
CYA 50
Water is 88 degrees
Salt is 2900
