Results 1 to 7 of 7
Thread: Bill from NY
    Jun 2014
    NY
    3
    Bill from NY
    Hello all
    I've recently bought a pool which just so happened to come with a house (really starting to feel that way). My fiance thought it would be nice to keep since we have a big family with lots of kids, so I'm trying to learn all I can. This forum has been a huge help and I'm using the BBB method.
    The pool itself was in horrid shape. "covered" for two years, blacker then coal, and without anything except an old sand filter.
    20,000 gallon 28ft above ground
    1 skimmer (Hayward) 1 return
    1 1/2 hp Hayward Power Flo pump (the one without an on/off switch)
    Hayward 180t Sand Filter with brand new valves (old one wouldn't even turn)
    Current levels
    FC over 5.0 (my kit test tube only goes to 5, but my ball park strip test shows 20 so guessing somewhere between)
    CC same as above.
    TA 80
    CYA 90 (I've been draining to skimmer bottom and refilling to lower the level slowly)
    PH 7.2 (having a **** of a time getting it raised to 7.5)
    I'm a big outdoors guy and cook so the deal was if I get this pool running I get to build me backyard brick oven! Let make it happen folks
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Bill from NY
    Welcome to TFP!
    Good to see that you are wanting to get things done, and make that pool sparkle.
    You might want to check outthis section of Pool School: http://www.troublefreepool.com/conte...its-comparison
    The kits shown there will test to 50ppm, with amazing accuracy.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Bill from NY
    A good test kit that we recommend is your best friend in helping you obtain that brick BBQ! Impossible to accurately maintain SLAM level without the fas-dpd chlorine test. No way to know what your true CC level is either with the one you have. You'll be much better off dropping that cya level with a larger water exchange than a couple inches at a time. Welcome to the forum.
    Jun 2014
    NY
    3
    Re: Bill from NY
    Thanks guys. I actually printed out the Pool School and bound it to keep as a reference book. Has stopped a couple of missteps so far.
    Hopefully have a better kit soon
    Jun 2014
    NY
    3
    Re: Bill from NY
    Probably a dumb question, but I figure I'd throw it out here. Should I drain the pool if it starts over flowing from the skimmer lid? Its above ground and there isn't a separate drain.
    Figure I could throw the filter to waste and "pump" out enough after the rain ends.
    20,000 gallon 28 ft above ground pool vinyl
    Hayward 1 1/2 hp Power Flo LX
    Hayward 180T Sand Filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Bill from NY
    Yes, do drain off extra water by whatever method works for your pool. It should be about 1/2 way up the skimmer opening.
    Casey's Avatar
    SW PA
    10,450
    Re: Bill from NY
    You will do so much better with the investment of the TF100 test kit. It is the number one tool you will use every day of the summer. Without it, everything is a guessing game.
