Thread: did i buy the appropriate pump?
    hi all, i have a 38,000 litre fibreglass saltwater pool. My sand filter is hayward s244t, my pump is hayward super II pump 1hp.
    Is this a good 'balance?'
    Reason i ask is because I've got some constant sand at the bottom of my pool. It's not from backwashing, it's a little bit everyday building up.
    I think it's either a broken lateral, or a spider gasket needing replacement?
    thankyou.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: did i buy the appropriate pump?
    The pump is a bit of overkill for your setup assuming you have no water features and may not be the most economical choice, but should work ok
