Results 1 to 17 of 17
Thread: Gone for 2 months and return to a swamp
    May 2014
    San Diego, CA
    35
    So, I've been fairly active here mostly asking questions over the last couple of months.
    The reason is I am in the Navy and have been away from home, and have been doing my homework by reading pool school, checking out the CYA charts, the Pool math, etc...
    Going through and reading the slime to sparkly stories have inspired me to do the TFP method, and I have my swamp to sparkly pool story.
    The story goes as this... We purchased the house last year, and the pool must have started with at least 100 CYA... from there it only got worse as I got pool stored. I wised up to the scam once I went in the store and was told I needed to "stabilize" my pool right after I was told to Shock it.
    Anyways, I decided that since I knew the CYA was high, I needed to order the TF-100 kit so i could test for myself... It was waiting for me when i got home 2 days ago.
    About a week before I returned home we had a filter blowout due to the lid clamp failing.
    I repaired the filter, and got started on the SLAM.
    Here are the pictures from about 6pm Wednesday to 5pm Friday
    Trust me... TFP method works...
    Now for the numbers.
    (Still in SLAM)
    FC 19
    CC 0
    CYA 45
    TA 120
    PH 7.4
    Thanks for all the advice all the pros here give!
    ~10,000 gallon IG painted plaster free-form pool w/ 1 skimmer and 1 main drain
    Intelliflo 3hp vs pump
    Pentair C/C 420 cartridge filter
    TF100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: Gone for 2 months and return to a swamp
    Well done!
    You've got it figured out -- pass it on and answer some questions!
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Great job!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    512
    Gorgeous! and BTW..my husband is a retired submariner..GO NAVY!
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    May 2014
    San Diego, CA
    35
    I just feel i got real lucky with this much progress in less than 48 hours.
    TF100 test kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Very nice!
    With a hearty Thank you for serving!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    SWEET! You did it! That is great for only 48 hours.
    Is that a lab I see behind the fence in one picture? Is the fence to keep him out of the pool???????? LOL We cannot allow our lab/mastiff mix on the deck unless we want to help him OUT of the pool! He gets in just fine by his self! The getting out is a problem.
    Kim
    May 2014
    San Diego, CA
    35
    Quote Originally Posted by kimkats View Post
    Kim
    He's actually a lab/st. bernard mix... he got into the pool a few times before we got the fence installed, even though his hair still ends up in the pool... he sheds a small chihuahua every day it seems.
    TF100 test kit
    Casey's Avatar
    SW PA
    10,453
    Congrats on defeating that green monster and thank you for your service!
    I have a German Rottweiler and I sweep up baby Rottweilers every 2 days.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am surprised your dog has trouble getting out, or is it just he does not want to?
    Ike
    Sep 2011
    Lumber City, Ga
    9
    What a change in only 48 hrs. Well done
    24x48 Atlantic AGP
    18" Hayward Sand Filter
    1 HP Hayward Powerflo LX
    Jul 2012
    Tallahassee, FL
    30,580
    He does not want to and our steps are the ladder like ones-straight up and down.
    I hear you on the hair. I have two dogs. Bos is an American Bulldog. He does not shed much. Bull is our Mastiff/ lab mix sheds a LOT! I brush and brush and brush (which he loves) and 30 mins. later can brush more out! Oh well I still love him! LOL
    Kim
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    This is obviously off topic but since the pool looks so nice (an inspiring story !!) I'll just point out that (believe it or not) vacuuming dogs is a great way to keep the hair under control. Some dogs never get to like it, but we had a couple of dogs that would follow anyone with a vacuum cleaner around the house and whine to be vacuumed.
    Vacuum once a day and you have an almost no-shed dog, much easier than crossing it with a poodle
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Compstuff's Avatar
    Jun 2014
    Miami Florida
    62
    Wow your pool came out great... time to enjoy
    POOL: 15 x 30 IG Plaster Pool With Spa about 15,900 Gal 1996
    Single Main Drain + Spa Drain + Single Skimmer
    FILTER: Purex Triton CC150 150GPM Cartridge Filter 31 x 10
    PUMP: Pentair SuperFlo SF-N1-1A + Pentair Model 320 Chlorinator
    Jul 2012
    Tallahassee, FL
    30,580
    If I give him a peanut butter kong I bet he would let me vacuum him! That is an idea! I will have to try it! THANKS!
    May 2014
    San Diego, CA
    35
    And here is the labrenard Jack in the pool
    TF100 test kit
    Jul 2012
    Tallahassee, FL
    30,580
    Looks like fun for all!
    Kim
