Thread: Hayward Pool first time start up
    Jun 2014
    Chicago IL
    2
    Just hooked up Hayward H150FD pool heater and trying to start for first time. Electric, gas and water hooked up. Followed instructions on pilot on and off setting. Set mode to pool, upped temp to 89. Temp 89 flashes then turns to error code 'LO', limit string open error. Troubleshooting guide no help to me with this error. Any thoughts or ideas?
    Casey's Avatar
    SW PA
    10,457
    Re: Hayward Pool first time start up
    Welcome to TFP.
    I can't help but I'm sure someone can.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I'm not sure, but it could be low flow.
    I assume you have the pump wired in to start anytime you want heat for your pool. Pump starts up ok like that?
    Jun 2014
    Chicago IL
    2
    Quote Originally Posted by Charlie_R View Post
    Low water flow? The pump was running water through the heater while I was trying to start it up.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Other than that, I've got no idea. Sorry I can't help your situation.
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    LO can mean a water flow problem as well as a limit error. Try jumping out the pressure switch and if it fires, you either have a bad pressure switch or your filter isn't as clean as you think it is.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
