Thread: No pressure in pump...help
    Jun 2014
    Bismarck, North Dakota
    28
    Just set up pool a couple days ago. Got it filled and had some questions answered on this site as per chemicals (thanks all.) Deep cleaned the sand filter yesterday as per video. Question #1 is the cap supposed to be on the bottom of the filter at all times? When I watched the "deep clean" tutorial, the first thing it said was put the cap on. The previous owner sent the cap but it is not currently on. After deep cleaning, does it stay on?
    Question 2 The water is being sucked into the skimmer and and is coming back into the pool in bursts. From what I read so far, it appears I have an air leak? Both PVC lines (the one from skimmer to pump/filter and the return line) are heavy with water. I removed the skimmer line and water poured out, so it does not seem to be plugged...
    Help Please...
    8600 gal/ag/Richwood Round 18 x52 swinn'play pool, Aquamaster sand filter, Waterway pump, install 6/25/14
    Jun 2014
    28
    Re: No pressure in pump...help
    Ok, update... Cap is on the bottom of the filter. Once the pump is running, I see that if the cap is off, water sprays everywhere. Pump seems to be working well. Gauge still reads zero. If I turn off the pump and take the gauge off so I can take it to the store to buy new, water shoots out the hole where gauge was screwed on. Any suggestions?
    Thanks
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Sounds like a bad gauge. They aren't the best quality and do fail.
    Bet a new one solves the problem.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Question 2 sounds like you have low water level or a stuck skimmer weir (the flap)
    The pump primes and starts shooting water out, it sucks the skimmer dry, sucks air, loses prime. Then the skimmer refills and the cycle starts all over.
    Jun 2014
    28
    Can you get a new gauge at hardware store or is it specific to the pump?
    Thanks
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    A hardware store or pool store should have one. Take the old one along so they can see what size pipe thread you need.
