Thread: What is attached to my pool timer?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Newbie here,
    Just moved to a home with a pool and a failed Intermatic pool timer. Installed a new one myself. 220 Volt model T104M. It's working great. The old (broken) timer had this thing soldered to the two hot sides of the switch. What is it (capacitor? surge protector? electrical noise suppressor)? Only wording on the attachment is a large A, a smaller AA and 65 in reverse letters, like looking through a mirror. What was it for? Do I need it?
    Thanks!
    Rob
    Aug 2011
    Middle TN
    83
    Re: What is attached to my pool timer?
    Hmmmm. No Idea. Maybe it's a battery or a capacitor that someone wired into the circuit to keep the clock part of the timer working in the event of a power failure? How heavy is it? Does it have a charge?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    It looks like a capacitor. It's probably to keep the points from arcing when the timer turns on and off.
