Results 1 to 7 of 7
Thread: Just did my first full test
    Jun 2014
    Mendon/MA
    20
    Just did my first full test with the TF100 and I am psyched with the results!
    Ph 7.7
    FC 4.5
    CC 0... Maybe .5
    CYA 80
    TA 150
    CH 275
    I tossed in about half a gallon of 12.5% chlorine to get the FC up. Process is super easy with the kit and my water is sparkling 80 degrees! Now I need to do the overnight test....
    Oh an I have been slowly getting my stabilizer level down since reading this site. Triclor tabs are no longer on the daily regiment!
    21k gallon IG vinyl with sand filter and single speed pump. Propane Hayward heater installed with no bypass valves.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Just did my first full test
    welcome! it's liberating, isn't it? knowing you have the knowledge to maintain control of your own pool....sigh.....sparklypoolitis!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Butterfly's Avatar
    South Carolina
    10,045
    Congrats on the TF100 test kit
    With CYA of 80, keep FC between 6 and 11, and never below 6.
    I suggest you dose up to 11 each evening, with pump running for at least 30 minutes after, and see where FC is the next evening. Soon you will learn your pool's appetite for FC and dose accordingly.
    Good!
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Ain't it amazing how easy it is when you have your own test kit? And how crystal clear the water is?
    The down side is that you can see every single dead bug, blade of grass, or piece of grit that ends up in the pool.
    You're probably also in the beginning stages of Sparklypoolitis, and inevitably it becomes terminal and you become a Pool Snob.
    golfinglenn's Avatar
    Jul 2013
    Springfield, OR
    96
    Isn't that test kit as easy as it gets? People kinda freak out when I pull it out and start doing some tests as it can look overwhelming, but the instructions are so clear and easy to follow. I don't know about the Taylor kit, but big thumbs up to TFT for the TF100 kit!!!
    6500 gal above ground Doughboy with 200lb sand filter and solar panel heater. Converted from Baqua to BBB and never looking back!!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Amen to that. Don't even mention what you see with the pool light on at night. What are all those infinitesimal particles doing in there?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Copy that ^^^ heh heh
