Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: New England Pool Project - Nearing Completion
    Jul 2013
    MA, USA
    39
    Last year, we decided to begin a transformation of our underutilized back yard. It was hilly, uneven, and quite honestly a bit of an eyesore....
    We knew it would take considerable time and expense, but as we are nearing completion I thought I would begin to share the transformation we underwent since I drew a lot of inspiration from other pools being shared on this site.
    Broke ground on 12/04/2013.
    jjwalker's Avatar
    S. Louisiana
    198
    Re: New England Pool Project - Nearing Completion
    very nice, you know we all love pics!!
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Mar 2013
    New Hampshire
    351
    I will assume more pics to come as this does not look near completion : )
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Casey's Avatar
    SW PA
    10,453
    Keep those pics a coming!!!
    Jul 2013
    MA, USA
    39
    Next set of pics takes us through the end of 2013:
    Jul 2013
    MA, USA
    39
    Once the snow was gone it was time for tile installation:
    Jul 2013
    MA, USA
    39
    Next up was building the first wall:
    Very nice! That retaining wall is outstanding!
    Jul 2013
    MA, USA
    39
    Thanks. It's a beautiful piece of masonry, but I think it's a bit too short (length not height) on the left of the stairs facing the house. Might need to amend that. Will get to a pic of that soon.
    Next up was the deck prepwork:
    Jul 2013
    MA, USA
    39
    And then the stamped concrete (Here's the photos that show the wall being too short IMO):
    Most of the wall looks at least 28" high. This gives the crowd a place to sit.
    Jul 2013
    MA, USA
    39
    If you look at the top photo in the last set (right side of wall facing house) vs the last photo (left side of wall when facing house). It seems like the wall should continue and come down in grade and that those three rocks look out of place.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    I would agree with that assessment of the wall aesthetics.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2013
    MA, USA
    39
    There will be another seating wall on the other side of around 18" in height. Hard to see in the above pics but there is an ~1' gap between the wall and deck that I will put down landscaping paper and river rock on. Same thing on other side. Still a couple weeks of work to go...
    IG 20'x32' Free-Form Gunite/White Marcite Plaster
    ~18,000 gallons, Taylor K-2006C Test Kit
    Pentair MT400LP Heater, IntelliChlor Generator, Clean & Clear Filter
    My Build Thread
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Love the pool! Love the wall BUT do agree with you about it being too short and the three rocks looking out of place. I thought they were just put there waiting to be put where they belong.......
    What is the gray stuff/area to the left? Do I see pool pipes sticking up on the left side of the house as well? If that is for stuff for the pool you are going to want easy, clean access to it that is easy on the feet.
    Thanks for sharing!
    Kim
    Jul 2013
    MA, USA
    39
    Thanks
    That's a spot for the shed, although we may adjust it somewhat. The pipes are indeed for the pool EQ. Was thinking of using the same river rock around that area but will consider the easy on the feet angle some more.
    My Build Thread
    Jul 2012
    Tallahassee, FL
    30,585
    I will tell you that I do most of the work on/with/to the pool is while I am dressed for the pool with bare feet so easy on the feet is a good idea for anything to do with the pool. Just wanted to throw that out there.
    Kim
    Nov 2013
    Miami, FL
    348
    The wall is amazing! I hope they can lengthen it for you. This will be a great pool when it is finished. I like the stamped concrete pattern you chose. I agree with kimkats's suggestion for being able to walk to pool equipment in bare feet or flipflops...
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Jul 2013
    MA, USA
    39
    Thanks Really looking forward to completion so we can get the landscaping underway. Should have some new pics in a week. I may take some blue stone that I had previously used under the deck and make a path through the river rock with that near the EQ so it's easy on the feet, so thanks again for that suggestion. Have a Happy 4th everyone!
    My Build Thread
  20. Back To Top    #20
    Jun 2014
    Sanger, TX
    555
    Agree with the comments that the stone work on the wall is really nice. It goes really well with the decking and the tile. Very cohesive design (Ranger Bob's wife - Karen)
    New in 2017, will update
