Thread: Question about my first SLAM and passing the OCLT with skimmers full of flowers...
    May 2014
    Clinton, Mississippi
    24
    I started getting a few small algae spots on pool and water got a bit dull so I started a SLAM... For 3 days now the water has been crystal clear but I am still losing 3ppm FC at night. I am wondering if the reason for the loss may be the fact that I have numerous Crapemertels (flowering trees - no idea if I spelled that right) around the pool and my skimmers are full of the flowers each morning. These flowers will be consuming some of the chlorine won't they? Should I ever expect to actually pass an OCLT with skimmers full of tiny flowers each morning? My CC is always .5 or less.
    ____________________________________________________________ ___________
    15,000 gallon in ground pool with liner, Purex Triton Tagelus sand filter, Pentair Superflo 1HP.... Clinton, MS.
    30,426
    Re: Question about my first SLAM and passing the OCLT with skimmers full of flowers..
    The crepe myrtle flowers will not have that much affect. You need to continue the SLAM.
    Butterfly's Avatar
    South Carolina
    10,045
    If you have lights, remove from niche and clean out and expose to high SLAM FC. Same for ladders, steps, ropes, bobbers, etc
    Scrub everything, including the skimmer throat.
    As Dave said, I don't think the flowers would eat that much FC, either.
    Yep, algae got a little foothold going on somewhere......
    You're done SLAMing when:
