Results 1 to 16 of 16
Thread: "Fill sand" for bottom of Intex pool?
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hello all-
    Should be leveled this weekend and hopefully starting sand! Will "Fill Sand" work?
    Thats what 3 places recommmended around me, $35 or so a yard. For a 16x48 most likely 3 yard?
    http://www.mtdiablolandscape.com/Pro...andandPath.htm
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: "Fill sand" for bottom of Intex pool?
    If your ground is level you most likely won't need 3 yards of sand. It all depends on what you are using the sand for. If you have pavers buried already for the legs, and are only using the sand to fill in wavy areas, it won't require much at all. If you are placing your pavers on top of your leveled ground, you'll likely need 2 or 3 yards. You will probably have leftover sand if you get 3 yards. But better to have too much than not enough. Just remember if you are using sand to bring pool bottom up to the level of your pavers, you need to have some way to contain the sand so it won't wash away.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Jun 2014
    206
    Thank you, grounds not too bad and clay-ish and using sand to fill in waves like you said . I got 12x12x 1.5 or 1.75" pavers. Best to bury 1" in ground? Just giving some padding... I also bout 80' of 5" terrace board to surround the pool.
    Leveling this weekend n hopefully setup
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    1" deep sand in a 18' circle will require .78 cubic yards of sand. So if you bury your pavers when you level them and leave 1" above ground 1 yard should be more than enough.
    http://www.ataktrucking.com/material...and-calculator
    After you spread and level your sand be sure to "rain" the sand in. You can use a water hose or a sprinkler to simulate rain to compact the sand. Dry sand just shifts around when you try to pack it.
    Jun 2014
    206
    Excellent thank you!! I assume thicker sand is more chance for footprints n such
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Once the pool is full, you don't have to worry about footprints. The weight of the pool will keep the sand from shifting underneath it. However, (hindsight is 20/20) the only thing I wish I would have remembered to do after working on the wrinkles is to reach under the pool where ladder was sitting and smooth out the divots that were left under it when we got in and out to work out wrinkles.
    Jun 2014
    206
    Thank you so much for the heads up! Hope to have it up this weekend and swim by 4th!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Also after reading up on poolmath and such, the starter chemicals I prob will be needing are CYA and standard bleach? Or am I missing something, sorry lots to read and I guess I need some numbers to run the calc after Im setup
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Have you got one of the recommended test kits? If not, get one on the way. The strips don't cut it. Be careful adding cya. It takes a while to show up on tests. Trust me.... I know from experience. It won't hurt anything to stock up on bleach. Once you test pH you might need some baking soda or muratic acid.
    Jun 2014
    206
    TF-100 is in my garage
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Good deal! Once you are all set up start a thread on TFPC forum if you need help.
    Jun 2014
    206
    Just to confirm, when bleach just regular concentrated 8.25% bleach or am I missing something?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Mar 2013
    Hendersonville, TN
    9
    That will work fine. Use the pool math calculator above when you are ready and make sure you change the percentage of the bleach to reflect what you have.
    Last Year: Pro Series Frame AGP 16' x 48" Approx 5,060 Gallons. 1500GPH pump, Cartridge filter in skimmer. TF-100 Test Kit
    Just Built 5/7/15: Doughboy 24' x 54" round above ground pool 16,000 gallons. Astral Pool 22" sand filter, Waterway 1 1/2 hp 2 speed pump. TF-100 Test Kit
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Do a full set of tests including CYA and use pool math to determine what you need to put in your pool!
    Jun 2014
    206
    U got it, just blows my mind u can use bleach lol
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Fillin er up
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
